Old 04-05-2004, 11:59 PM
FletchTrick FletchTrick is offline
Need a DSM expert please
Hello,
I have posted and no one has replied so I will try again. While driving my 1990 Elipse, it started chugging hard and cutting out and finally died. I smelled electrical which turned out to be the ECM. It was fried pretty bad. Replaced it. Also replaced the fuel pump relay. Car will still not start. Can someone please tell me if the ECM has to be re-booted or programmed or what? I have already tried clearing any stored codes. Also, the fuel pump does not come on when I turn the key on but comes on with jumper wires from the battery. Any info is much appreciated. Still five weeks...no car.
Old 04-06-2004, 03:34 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
does your car turn over fine without jumper cables? if not then obivously you either need a new battery or you need to charge the one you have! then your fuel pump should kick in just fine!
Old 04-06-2004, 08:28 PM
Re: Need a DSM expert please
Yeah it turns over fine without jumper cables. The housing on the fuel pump relay was kinda hanging off it so I pushed on it and the car started turning over with keys in ignition. I was thinking maybe a short? Any other clues? Thanks in advance.
Old 04-06-2004, 11:37 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Do the standard process.
Do you have spark? Fuel to the fuel rail? Power to the injectors?
Old 04-07-2004, 12:15 PM
There is spark, no gas to the fuel rail or not enough, have not checked for power to the injectors. There is no power to the fuel pump when you turn the key on. Only when the engine is being cranked over. What's my next step? Thanks in advance.
Old 04-07-2004, 03:03 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
isn't that the crank angle sensor? like if it is busted there will be no fuel pump comming on? i remember something about that, or like that...
vibration problem need an expert my rsx is falling apart need HELP!!! 2003rsxtypes Let's get Technical! 1 09-27-2009 05:48 PM
DSM experts! How can I get more Horse power? e-flightvic Engine, Transmission and Drivetrain 7 05-30-2006 10:58 PM
Need some expert advice please! DannyC4 Corvette 5 02-21-2006 10:30 PM
dsm experts needed on swap info greykiddd15 Off-Topic 2 04-07-2004 01:38 PM
All Impreza Experts, Please Help! J_Spec_NiTeMaRe Impreza/9-2x/Outback Sport 4 07-01-2002 12:30 PM
