Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-05-2004, 10:16 PM
fenderbinder fenderbinder is offline
Angry 1991 D150 clutch problem
I replaced the clutch on my 1991 D150 Ram 4 wheel drive pickup, and am having trouble shifting now. I also replaced the hydraulic clutch slave cylinder. I have bled the system several time, but that doesn't help. If I pump the clutch, the truck shifts ok. I got the replacement parts from O'rileys. Could I have gotten the wrong slave cylinder, and the actuator rod is not long enough to give me sufficient travel to disengage the clutch? Any help would be greatly appreciated.
Old 04-05-2004, 10:25 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: 1991 D150 clutch problem
This same thing happened to my friend's truck, but I can't remember what it was that caused it, and this was right after the clutch was done. I don't know where he is right now either, sorry dude...
Old 04-05-2004, 11:10 PM
pind pind is offline
if your new slave cylinder has an ordinary bleed screw on it, try back bleeding it, with a brake bal r other low pressure device. this will make sure that all the air is forced to the top of the system, and out through the master cylinder and reservoir.
This is the best way to ensure proper operation, if it is an option. I have spent way too much time using conventional bleeding procedures. Taken hours off my life that could be better spent doing nothing.
Good luck on the clutch setup, happy motoring.
And, BleedDodge, you are a fountain of wisdom tonight huh?
Old 04-06-2004, 07:57 PM
BleedDodge's Avatar
It wasn't something like that. It was mechanical.
1991 wont start..motor from 1985 no spark HELP rwoodxtreme C/K 4 01-31-2010 10:19 AM
clutch problem..i think bov3220 Engine, Transmission and Drivetrain 4 05-22-2009 12:17 PM
1991 Camry Problems, HELP!! toyota_camry Camry/Camry Hybrid/Vista 4 04-10-2009 08:15 PM
CLUTCH problem, Exhaust problem alesserfate 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 16 10-06-2004 07:46 PM
1991 D150 Oxygen sensor not switching 318 TBI engine srip64 Ram Pickup | Ram SRT10 1 08-22-2004 11:43 PM
