Old 04-05-2004, 05:01 PM
behvah78's Avatar
behvah78 behvah78 is offline
O2 Sensor
I have my after cat o2 removed and my engine light goes on but the fuel efficiency hasn't changed. Is the other sensor doing the job? do i need to replace it or get an emulator??
"Never drive faster than your Guardian Angel can fly."
[img]
http://us.f2.yahoofs.com/users/41b4f...__sr_/f414.jpg [/img]
Old 04-05-2004, 07:27 PM
99_gtp 99_gtp is offline
Re: O2 Sensor
you need a o2 simulator its on sale right now at zzperformance $37.00
being blown is better than being thrown
Old 04-06-2004, 01:00 PM
sonhasteg sonhasteg is offline
The before cat 02 sensor is used to monitor A/F ratio. The majority of experts out there say that the after cat 02 is there just to monitor wether the Cat is working properly or not. There are a few that believe the 2nd 02 does effect A/F in some part throttle cruising conditions, but I have never heard of anyone having an A/F problem with the rear 02 disconnected.
Curious to know why you removed the after cat 02? It's unclear by your post if you removed the cat itself. If you want to leave it out and clear the SES...99 GTP has your answer.
Old 04-06-2004, 04:14 PM
behvah78's Avatar
Re: O2 Sensor
Well I removed it because it was broken when I removed my u-bent. The only thing that worries me is that I might not pass the aircare with no o2 and the camshafts I'm gonna get. Will the simulator help me pass it?
[img]
Old 04-06-2004, 07:59 PM
Don't know about Canada, but I've heard that in states that require a smog test an SES light is an automatic failure. As far as cams...the ClubGP board has several stories of people passing even with radical cams, but also have stories of people failing with mild cams. Not what you want to hear, but it looks like it just depends...
o2 sensor danielgast46 F Series 0 03-15-2009 09:39 PM
Replacing Evap. canister Control Valve, Boost Sensor, and Knock Sensor? raja Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 16 06-04-2007 03:25 AM
Knock sensor and O2 sensor jmmax Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 02-24-2004 11:51 AM
