Old 04-05-2004, 03:45 PM
oasjoey oasjoey is offline
91 cavalier transaxle
I swapped the tranaxle in my 91 cavalier with one I found at a salvage yard. After I got it installed I noticed that the torque converter would not engage in any gear. Fluid level is good. Any help on this would be appreciated.
Old 04-15-2004, 11:11 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
did you make sure the TC was engaged into the front pump all the way both clicks ?? if not then it wont run the pump, have to push and spin the TC a bunch to get it to click in all the way, sometimes its a pain and hard to tell if its all way into the pomp into the splines and notches both
if its in all the way for sure and the tranny does nothing at all ever, then id say its trash unless maybe someoen forgot to install the screen inside under the pan, salveage yards like to remove the pan and screens when they sell a tranny, commonly done here anyways i assume so that you cant see how much junk is in the pan so that you can complani about the clutch disc material and/or metal particles that are usually accumulated in the higher mileage tranny pans
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
HELP!!! Transaxle removal (it's stuck in the car) babychazz Eclipse 2000+ 1 07-31-2010 04:03 PM
nailing down Transaxle code P0742 bsmith51 Bonneville 1 03-19-2010 02:12 PM
2001 Cavalier Battery Drain Problem - HELP amberdamber7 Cavalier Problem Diagnosis 25 03-25-2009 06:30 PM
2001 Cavalier hizkid42 Cavalier Problem Diagnosis 2 03-07-2009 08:20 AM
1996 Cavalier Douglas91 Cavalier Problem Diagnosis 7 02-21-2009 06:53 AM
