Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 04-05-2004, 03:43 PM
ghutchin ghutchin is offline
95 Engine Mis-Firing Detection
Are the 95 PCM's capable of detecting when the engine is missing?
Thanks
-Glenn
Old 04-05-2004, 10:06 PM
KillerKeller_jr's Avatar
KillerKeller_jr KillerKeller_jr is offline
Sounds like you might need to replace your spark plugs and wires. Use factory AC Delco plugs and wires, they might cost a lot but it should probably fix you mis-firing problem. Do a search for spark plugs and you will find several other threads that speak about mis-firing. Try that and let us know if that fixes it. Good luck...
Old 04-06-2004, 12:13 AM
I don't know if its missing
I'm just curious if the Computers in the 95's had the capability to detect misfires. I know 96 and up did because this is a requirement of OBDII.
Old 04-06-2004, 12:53 AM
97 silverbullet's Avatar
97 silverbullet 97 silverbullet is offline
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
Re: 95 Engine Mis-Firing Detection
read the manual, it says if the check engine light comes on and flashes its a misfire
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 04-08-2004, 06:15 PM
dsatt12 dsatt12 is offline
When I had a worn out set of wires my 95 had codes that said it was misfiring- or so my mechanic said. I didn't have my scan tool yet. I can't recall that it was ever flashing the SES light on and off though. It's possible I just didn't notice since that light seems to be behind the steering wheel unless I tilt it up or start to turn.
2000 exp sport OHV mis-firing. nitrowizard88 Explorer | Explorer Sport Trac 4 07-02-2010 02:47 PM
#3 cylender mis firing..why glenkarp Explorer | Explorer Sport Trac 1 01-02-2004 05:56 PM
HELP! MY car is mis-firing!!!? speedyeclipsee Street Racing 0 04-28-2002 05:54 PM
