Old 04-05-2004, 01:42 PM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
stereo went out
I first had this problem in December, I went out to my car, turned it on, tried to turn on the radio and nothing. The stereo has power, it displays stations and runs cd's, but i get nothing through the speakers. Later that day i tried it again and it came on. Recently though its been going out for days and sometimes it will come on for about a minute then it will make a kind of pop noise and just stop. I've noticed the only times it comes on is if the volume is all the way down and turned off before the car is started, then i start the car (with the air off), and sometimes i can turn the stereo on and turn up the volume and it will work. Do you have any ideas about this at all?
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 04-05-2004, 01:58 PM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
Re: stereo went out
sounds like some loose wires to me. Recheck the wiring if its an aftermarket radio.
'93 Honda Civic EJ2
'90 Civic HB w/ d16z6 swap: SOLD!!!
Old 04-05-2004, 02:25 PM
kittman's Avatar
kittman kittman is offline
I had similar problems. The power lead to one of my amps had a small amount of exposed wire at the connector. It would touch the frame and snap, crackle, and pop, no tunes. I found the offending wire, applied a small amount of electrical tape, and voila! Tunes.
cheers
My beloved '89 Civic Si, May She Rest In Pieces
The Accords
Old 04-05-2004, 04:58 PM
nemo_wolf's Avatar
nemo_wolf nemo_wolf is offline
Send a message via AIM to nemo_wolf Send a message via MSN to nemo_wolf Send a message via Yahoo to nemo_wolf
Re: stereo went out
i do want to add depending on your familiarity with working on exposed wires you may want to unplug your battery just incase you touch a live wire and zap the hell outa yourself. Or worse, cause a short somewhere else in the wiring and fry a few fuses.
I sure dont want to ever have that happen.
AF Bay Area Crew
91 civic LX sedan : Dec. 3rd 01 - Dec. 9th 02
88 civic DX hatch : Jan 14th 03 - Oct 05
96 Zamboni Model 552 : done working there
00 Civic EX coupe : Oct 05 - Sept 2010
11 Scion xB : Sept 2010 - Present
Old 04-06-2004, 12:39 AM
Jay eS Iye's Avatar
Re: stereo went out
well its kinda weird that this would happen now, the stereo has been in the car for years with no problems. but i'll hafta go out there and check all the wires i guess
climate control went out...HELP! its cold out!! nupestp Intrigue 0 11-23-2007 06:47 PM
help i put in a stereo and my tale lights went out kodyb Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 4 10-28-2006 10:50 PM
help i put in a stereo and my tale lights went out kodyb Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 10-18-2006 05:12 AM
Stereo went out Jay eS Iye Car Audio 3 04-11-2004 04:54 PM
Front Panel Lights went out after installing new stereo deck dmandave Legacy / Liberty / Baja 5 12-06-2003 08:03 AM
