Old 04-05-2004, 02:30 AM
Beegle Beegle is offline
Will my struts fit?
My '89 was lowered before I bought it (i think maybe two inches) and I am about to put some new struts on the front, but I'm not sure if the factory size struts will still fit on it since it's been lowered. Will they be too big, or do the struts have nothing to do with lowering the car?
Old 04-05-2004, 03:24 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Will my struts fit?
When cars are lowered they are typically done though different rate coil springs. The struts will have nothing to do with it. But depending on the amount it has been lowered, you may have to buy after-market caster/camber plates to ensure proper front end alignment.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 04-05-2004, 11:56 AM
john67 john67 is offline
A possible low buck alternative to the caster camber plates is slotting out the mounting holes on the strut where it bolts to the spindle. A guy at a alignment shop in my area told me about this. Don't know what the limits of adjustment are with this method.
Old 04-05-2004, 12:35 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Slotting those spindles sounds like a lot of work and an innacurate sciences to me. As far as the drop I would get aftermarket stiffer shocks with drops springs to balance the ride out. But the shocks have nothing to do with your ride hieght that's all the springs like HiFlow said.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 04-05-2004, 03:12 PM
GTStang, not the spindle, slot the holes in the strut. Actually I think they're slotted some already. You're right, its a trial and error thing but like I said, its a lowbuck alternative. Plus, it was the alignment guy's suggestion, so it must not be too big a deal.
Old 04-05-2004, 03:44 PM
HiFlow5 0's Avatar
Stanger
That will give you some adjustment down at the base of the struts, but what about the top? How are you going to correct the angle of the strut to accommodate the lower stance of the car?
-2013 Ford Flex
-1999 Ford F150
Old 04-06-2004, 06:35 AM
HiFlow5 0, I'm not a alignment guy and never claimed to be. If the car NEEDS the caster camber plates, Beegle should go for it. But I would let the alignment shop determine that.
Old 04-06-2004, 09:37 AM
FoxGranadaChuck FoxGranadaChuck is offline
Whether or not you go with the caster/camber plates (I would do so!), I would upgrade to '90-93 tie rod ends.
Maximum Motorsports recommends these to reduce bump-steer when Mustangs are lowered to this extent.
Old 04-07-2004, 02:13 AM
Thanks everyone. Your input really helped. I'll see what I can do.
Old 04-07-2004, 07:34 AM
Cool
You're more than welcome!!!
