Go Back   Automotive Forums Car Chat > Buick > Century
Old 04-04-2004, 01:27 PM
bigG bigG is offline
Send a message via AIM to bigG Send a message via Yahoo to bigG
checking engine codes - 96 century
Can you still check the engine codes by shorting the diag port to the grnd port? which ports are which, there are 3 on the top of the connector and 4 on the bottom. where can I get a list of the codes?
Old 04-09-2004, 03:19 PM
bignoisey bignoisey is offline
NO. You can't get the codes by shorting pins any longer.
From '96 on, the systems are ODBII. You need an ODBII scan tool. And actually its worth the investment if you do much of your own work at all. I shopped around and found a basic tool which is really a cable with a box in the middle that I hook up to my laptop computer. I paid less than $90 and it works on any of the three ODBII standards. Also you often can only reset the check engine light with this tool. If interested look at http://obddiagnostics.com/index.html. If you want to see more info on many ODBII scanners do an internet search on "ODBII" there's a ton of information on all kinds of products. Saving 1 or 2 trips to a diagnostic center usually pays for it.
Old 04-11-2004, 08:54 AM
Wink Re: checking engine codes - 96 century
Thanks for the info. I am glad I did not try to short out the pins like I used to do with older models.
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
1998 Malibu - check engine light jpar1983 Malibu 2 10-28-2009 07:49 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
