Old 04-03-2004, 02:18 PM
WB64 WB64 is offline
Fuel inertia (shut off) switch
I have a 1996 Ford F150 XLT. I need to change the fuel filter but can't find the fuel shut off switch to relieve pressure in the fuel line. My Haynes manuel shows it to the left of the brake pedal in the fire wall but it's not there. Any suggestions?
Old 04-03-2004, 02:39 PM
pind pind is offline
Re: Fuel inertia (shut off) switch
It should be there, high up, just above and to the left of the steering column. Its encased in somewhat of a cage, with just enough of an opening at the top to allow you to press the button for reset.
Old 04-03-2004, 04:29 PM
ModMech's Avatar
ModMech ModMech is offline
You don't need to mess with the inertia switch. All you should do is to remove the plastic "valve stem cap" on the fuel rail and using a rag to keep the mess to a minimum, depress the core to relieve the pressure. Then you can simply replace the fuel filter.
Odd occurrance - Inertia Switch Pulled Yahwehdo Taurus | Taurus Wagon 12 12-19-2010 10:31 AM
Lumina inertia switch location rmprdl1964 Lumina 5 05-11-2009 08:29 PM
Fuel Pump Shut Off Switch tekrator Ranger | Courier 1 10-14-2007 10:53 PM
mazda protege 2002 fuel shut off switch bulbash F Series 1 06-19-2004 09:47 PM
Fuel Pump Shut Off Switch? Takeshi_Nakazato F Series 3 11-19-2003 09:27 AM
