Go Back   Automotive Forums Car Chat > Toyota > Supra > Performance
Performance Talk about anything having to do with performance & mods.
Old 04-03-2004, 09:52 AM
1988suprakid 1988suprakid is offline
gauges
im swaping a non turbo auto to a turbo auto . what going to happen wiht the gauges in that car when i put the new motor in . what gauges are to work if any at all.
Old 04-03-2004, 10:31 AM
projectsupramk3's Avatar
projectsupramk3 projectsupramk3 is offline
Send a message via AIM to projectsupramk3
Re: gauges
All gauges except the tach will work perfectly, there is a resistor in the tachometer that needs to be changed, or simply get a turbo tach from the same year (87-88 or 89-92) Turbo Supra. The only thing you'll need is an aftermarket boost gauge and a place to mount it, then you can keep your voltmeter.
Installation Connection Problem: 0-Gauge to 8-Gauge, or Alternate? OnThePike Car Audio 10 12-03-2010 12:49 PM
'04 Tahoe Range/Fuel gauge problem. usn_622 Tahoe 2 02-21-2009 09:58 PM
Should I get another gauge or just order a boost gauge? urmystlkal Off-Topic 4 01-27-2004 06:54 PM
2001 Expolrer-Check Gauge Light/Temp Gauge cmroth12 Explorer | Explorer Sport Trac 0 12-29-2003 01:11 PM
