Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 04-02-2004, 08:05 PM
joseph970525 joseph970525 is offline
It does not start anytime ???? HELP
I have a problem with my Explorer '97... it do not start...
I have changed the fuel pump, injectors, fuses, relays, sparks,etc.
what i have found is that the fuel pump is not working, and even the distribuitor coil it does not work...
What can be the problem..
Old 04-12-2004, 01:39 PM
JODTRIK JODTRIK is offline
hAD THE SAME PROBLEM
My wife has a 98 explorer that would turn over just fine and it acted like it wanted to start so bad but just would fire up. I took it to the dealership and get ready, this one blew me away. Ther is a chip inside the ignition key that went bad and it is part of the anti-theft junk they are building into them these days. had to get a new key and have it re-programmed. I check for other opinions from several other dealerships and they say this is a common problem. Guess what it fixed the problem.
Old 04-13-2004, 06:49 AM
Opera House Opera House is offline
Re: It does not start anytime ???? HELP
I know what the problem is......... You bought everything but a manual. If you don't have spark, there is no reason to buy a fuel pump. That only comes on for a couple of seconds anyway. I recently bought 15 digital meters at Harbor Freight for $2.99 each so there is no reason why you can't get one. Step by step diagnostics is the way to solve problems. Start by finding out if there is any voltage at the coil pack connector and if the fuel pump turns on for three seconds when the key is turned on.
Old 04-30-2004, 01:29 AM
Dougs97 Dougs97 is offline
No start?
One by one.
1. Does the engine turn over?
2. Is fuel getting to the spark plugs?
3. Is electricity getting to the spark plugs?
Old 04-30-2004, 07:41 AM
Look in the manual and locate the ECM relay under the hood in the distribution box. With the key on, pull out this relay and feel if it clicks off. The ECM relay has a diode in series with it to keep the system from turning on if the battery is installed backwards. The diode may be open. This diode is located close by and looks like a black fuse. I have heard two reports of this diode melting for some unknown reason.
car does not start, everything works, please help ajmal March | Micra |Cube 2 09-18-2015 11:36 AM
2000 Alero V6 will not start. Please help. slavetothought Alero 1 10-28-2010 08:45 AM
93 villager no click no crank no start klee2183 Villager 1 02-28-2009 08:04 AM
My Civic 94 EX does not start......please help. lams '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 02-25-2008 09:13 PM
Help please! '94 does not start at random times rgs9292 Ninety Eight 2 01-06-2004 08:52 PM
