Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 04-02-2004, 08:44 AM
bayleemine bayleemine is offline
Unhappy Sunfire steering noise
HELP please. my 2001 sunfire is making a rubbing type of noise inside the car when turning the steering wheel. You can't hear it outside the car. It is driving me crazy and I'm afraid something is going to break. Anyone solved this problem? Thanks
Old 09-06-2004, 07:25 PM
cmitchby cmitchby is offline
Re: Sunfire steering noise
This will sound pretty stupid, but that's how I felt after discovering the cause of a worrisome steering noise in my '95 after days of trying to track it down. I only noticed it when making sharp turns in the parking lot. It sounded like something was loose/knocking and just waiting to fall off. Turns out the floor mat had worked its way up enough to rub on the steering assembly. May not be your problem, but check the floor mat for wear in the center and move it back to normal position before making a trip to the mechanic.
Old 09-07-2004, 01:44 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Cmitchby, I like your keep it simple philosophy. If it sounds like when you run your fingers on a nylon jacket, I would agree that it's something rubbing on the steering column, either the carpet where the column goes thru the firewall, or maybe a floormat out of place.
Steering noise grandpax2 Century 1 06-28-2010 06:50 PM
Creaking Noise At Front-End el ratfink Pacifica 2 12-05-2009 11:57 AM
99 Sunfire GT 2.4L Twin Cam Auto--CLICKING NOISES FROM ENGINE BLOCK E. Frank Cavalier Problem Diagnosis 8 07-28-2009 06:25 PM
brake noise and steering noises! cmacartney Escape | Maverick | Escape Hybrid 6 08-15-2006 10:38 AM
Power steering noise after flushing/changing the steering fluid Camry 2001 Mark11 Camry/Camry Hybrid/Vista 4 01-14-2006 08:16 AM
