Go Back   Automotive Forums .com Car Chat > Ford > Thunderbird
Old 04-02-2004, 07:11 AM   #1
turborich
1988 turbo coupe looses power around 3,500 rpm.
i own a 1988 thunderbird turbo coupe. the car seems to loose power around 3,500 rpms or so. it seems like it flattens out. i have an adjustable boost valve on it and it runs a t 18 psi where i have it set at. ive installed new plugs, wires, cap, rotor, checked for vacuum leaks, checked fuel pressure, i'm not getting any engine codes, it's a 5 speed. anyone one have any ideas???
turborich is offline   Reply With Quote
Old 04-02-2004, 11:34 PM   #2
thunderbird muscle
thunderbird muscle's Avatar
Re: 1988 turbo coupe looses power around 3,500 rpm.
Is the boost valve working properly?
It 3,500 should be around the begining of your real boost.
thunderbird muscle is offline   Reply With Quote
Old 04-14-2004, 11:38 PM   #3
g_lower
try pulling your valve cover and checking your rocker arms and your cam lobes. my 83 had the same problems and it ended up being a flat cam. thanks Graham
g_lower is offline   Reply With Quote
Old 04-15-2004, 07:33 PM   #4
jlewis
Send a message via AIM to jlewis
That's a hard one to diagnose exactly. I'd have to side with the cam idea too. You could have a damaged cam lobe that is not running enough lift and so it chokes at higher rpm. Also make sure the exhaust and intake(filter) are not stopped up. The converter's not stopped up is it? This would also make it choke at high rpm. And the last thing I can think of is that if your knock sensor is hooked up then it could be malfunctioning or something may be causing excessive knock in your engine(bad gas or wrong timing) and the sensor is pulling a lot of timing. This is actually really common on these, they'll run like a dog if the knock sensor pulls timing. You could try unhooking it but only if you know what knock sounds like. Then drive it and listen for pinging, knocking, whatever you call it. Then figure out what's causing that if you hear knock. If it doesn't knock and still runs bad with the knock sensor unhooked than look elsewhere. This is probably the easiest thing to check. I have the same car as you and I unhooked the knock sensor. I run premium(93), 11° BTDC, and 17 psi. Haven't heard any knock yet.
jlewis is offline   Reply With Quote
94 Jeep Grand wont go over 3,500 rpms AndyHansen Grand Cherokee | Grand Cherokee SRT8 5 03-10-2008 08:24 AM
1988 turbo coupe t-bird/turbo problems bassjam Thunderbird 1 12-18-2007 08:07 PM
Humongous loss of power after 3,000 rpms, help? pro_am Camaro Discussions 0 04-03-2006 09:29 PM
Wanted: 1987-1988 Turbo Coupe Mike_N Thunderbird 0 06-14-2005 12:49 PM
