Old 04-02-2004, 02:10 AM
burnM's Avatar
burnM burnM is offline
Would it fit?
Would a Cadillac big block fit in a '79 Camaro if it is already set up for an Oldsmobile big block? What I mean is, would the engine mounts need to be relocated or changed. Could I use the same tranny?
I found out that the engine in my Camaro is an Olds 350. Needless to say, I am disappointed. 160 hp on a good day- 220lbs feet of torque.
I have an old Caddy engine sitting in the corner of the shop. I'm not sure if it's a 472 or a 501. I've never seen something like that in a Camaro before. I would like to see what it could do with that kind of power and torque. From what I see on the web, they are easier to find parts for than an Olds. Not to mention that they make more power, or CAN make more power quite easily.
Thoughts and opinions? Maybe someone can point me in the right direction for info?
Thanks, B
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out
1995 9C1 Caprice - winter beater
1994 Impala SS - newest project
1991 9C1 Caprice - (rip)
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
Old 04-02-2004, 06:46 PM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
Re: Would it fit?
If that's what you want to do then go for it. However; I don't believe that big block caddy will easily fit in you camaro..might since there is some room in there but it will be tight. An olds/caddy/pontiac small block is almost the size of a big block chevy so you deffinatly will have to move the mounts and possibly do some shaving. No for an opinion, go with a chevy big block if your going that route. The caddy big block did have some power and torque, but it wasn't meant for what you're wanting it for. It was mostly bottom to mid range power. And as big as that engine is it only has two bolt mains. You can get some good power out of it, but it's probably not going to be worth the effort. If your willing to dump a lot of money into it to strenghen the block then yeah go for it, I'm sure you could easily get 800hp out of it, but you'll need to have it machined for four bolt mains and find the caps, and have the block shot peened and maginfluxed. Good luck though.
What Engine Would Fit In Mirage! lancerguy Lancer 20 03-10-2009 12:12 AM
Hybrid small car would fit Honda's plans Automotive News Automotive News Desk 0 02-27-2006 12:10 AM
Does Anyone Have Any Wheels That Would Fit My 2000 Sonoma 2wd? BILLYBOBERENO Cars/Parts for Sale/Exchange 0 06-09-2004 07:27 PM
Anybody kits would fit possibly? SpecVSpic Sentra | 200SX (USDM FWD) 0 06-03-2004 01:39 AM
