Old 04-02-2004, 02:09 AM
digicidal digicidal is offline
Gauge cluster questions...
Does anyone know a good source for specs on the gauge clusters and wiring from different years of Civics... the reason I ask is because I was looking at my friends 2000 SI and the gauge sizes seem to be the same as the ones in my 92 civic... of course the cluster is totally different shape and the wiring is different, but if the gauges are the same size and the connections are similar from the harness, I think it should be possible to replace the tach, spedo, and fuel/temp dials into the other cluster housing and just re-route wires if necessary for the appropriate leads.
However since I don't have the Manuals for the other years yet... (I'll get them if it is even remotely possible) - I don't know. I searched the forums and didn't see anyone that had tried this. If anyone can point me in the right direction I'll be happy to write up a detailed tutorial and post it if/when I conquer this beast.
I'm not afraid of a soldering iron in the least, and if necessary am willing to do my own IC project board if the carrier signals need to be adjusted in voltage, etc... in order to have the 2000 SI gauges work on the 92 ECU signals for the cluster. Any help is greatly appreciated... if nothing exists - look back here for the completed tutorial... I'm gonna do this even if I have to custom fabricate everything myself.
Old 04-02-2004, 03:16 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Gauge cluster questions...
Might be easier to just swap the clusters if you are going to fabricate, especially if you can work well with fiberglass. Whatever you do, good luck on it and I will be waiting for the details and pics. Sorry I couldn't give you any info though.
Empty Pockets Racing Member #1
Old 04-02-2004, 04:34 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Each individual meter gauge (speedo, tach, temp/fuel) can be bought and taken apart seperately. Weather or not you can cross platfor 5th gen cluster meters to 6th gen cluster meters, I'm not sure of. Wiring should be very similar though however I'd imagine...
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 04-02-2004, 10:08 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Just use the Si's plugs. Get the wiring schematics for both cars, and repin the Si's plug with the corresponding wires from you car. As far as the fitment goes. it will probably require a bracket to be made so you can get all four screws in. Not hard. And if you make your own bracket, you can adjust fitment to make it as un noticable as possible, since it will more than likely not line up correctly with your bezel. Most of the GSR swaps I have seen, the cluster sits too low and cuts off about a centimeter from the bottom of the gauges.
Gauge Cluster Question DJ_Inevitable '88 - '91 Civic | CRX | Wagon | Shuttlee 2 02-12-2004 06:26 AM
gauge cluster question YZ125rider21 '88 - '91 Civic | CRX | Wagon | Shuttlee 6 01-27-2004 10:10 PM
Gauge Cluster Questions SlowHatchGrL '88 - '91 Civic | CRX | Wagon | Shuttlee 5 12-09-2003 06:56 PM
90-91 jdm SiR gauge cluster question 91civicRacer '88 - '91 Civic | CRX | Wagon | Shuttlee 5 10-25-2002 12:01 AM
gauge cluster question Racincc85 Engineering/ Technical 2 09-30-2002 03:05 AM
