Go Back   Automotive Forums Car Chat > Honda > Integra
Old 04-02-2004, 12:23 AM
tegerick tegerick is offline
Send a message via AIM to tegerick
wondering if there is a difference
hey any of yall know if ther is a difference between integra gsr and ls fuel pump?
Old 04-02-2004, 12:02 PM
Re: wondering if there is a difference
i guess no one knows then
Old 04-02-2004, 06:20 PM
Kirwan Kirwan is offline
You might have to wait a little more than 12 hours for the right person to come along. This isn't a very fast moving board.
Without any actual experience in the matter, I'd guess that they use the same fuel pump. These fuel injected cars use a pressurized system with return bypass; there's a fair amount of tweaking that can be done by setting the fuel pressure regulator, so long as the pump puts out enough flow. I doubt the difference between 140 and 190 hp is enough fuel flow to require a different pump. Back when I did mustangs, we didn't go to larger pumps until we'd almost doubled the stock HP (from 225 to 400).
Old 04-02-2004, 08:08 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
They are the same. You don't need a larger one unless you are going to see 250 ish hp.
Old 04-02-2004, 08:56 PM
what about when the vtec come in does that make a diff. shouldnt a gsr be more powful then a ls
Old 04-02-2004, 09:19 PM
whtteg's Avatar
No the fuel pressure is changed by vacum and the extra fuel is delivered by changing the duty cycle of the injectors and the extra fuel pressure.
Old 04-02-2004, 09:24 PM
so i guess all the honda and acura pumps are the same?
Old 04-02-2004, 09:34 PM
whtteg's Avatar
No just the different modles of integra's. If yoiu want a higher flowing fuel pump then buy a Walboro they cost like $98 and flow 255lph.
Old 04-03-2004, 02:19 PM
well thanks guys
is there different 4l60e's BHolm Express | G Van 3 04-13-2008 12:50 AM
94 Flywheel are there different ones spoonman28 Ram Pickup | Ram SRT10 0 10-20-2005 01:09 PM
is there different kinds of motors for the 99 mercury cougar zeus999 Cougar 3 08-27-2005 05:21 PM
OEM Brake part #'s? Are there different Ramblin Fever Rodeo | Passport | MU 0 04-10-2005 12:21 PM
