Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 04-01-2004, 12:51 PM
sirryan sirryan is offline
Rear add-a-leaf/Pinion Angle
Hi All,
I have just installed a rear add-a-leaf on a 2000 4x4 Extended Cab TRD. It is working great and has helped alot with rear axle-wrap off road as well as on road ride and handling for my taste. However, one thing I did not think about before doing this is how it is affecting the angle between my rear drive shaft and rear diff. Pinion Angle? Does anyone know how to check this angle and what would be within specs? The add-a-leaf raised my truck about 2 inches in the rear.
Thanks for any help.
Ryan
Old 04-02-2004, 06:46 PM
superjoe83 superjoe83 is offline
Send a message via AIM to superjoe83
Re: Rear add-a-leaf/Pinion Angle
the add-a-leaf will not change your pinion angle, just your u-joint angles
If it aint broke, fix it anyway
pinion angle David Eastman GTRA / GTWS / GTS 19 04-17-2013 09:13 AM
XJ Rear Leaf Spring Swap Problems Jim Aldrich Cherokee 1 04-04-2010 08:25 PM
Add a leaf, leaf spring helper ColoradoSilverado Silverado 1 04-06-2006 12:05 AM
Calmini Add-A-Leafs and Shackles installation ozxterra Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 11 05-19-2002 01:20 PM
Rancho Add-A-Leaf Part # Philosopher Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 06-07-2001 12:09 PM
