Old 04-01-2004, 12:38 PM
paragoat paragoat is offline
Another Vibration question
I have a 2001 Silverado Extra Cab 1500 with a 5.3 liter and is lowered by at least 4 inches. While crusing on the highway a vibration starts to occur at around 75MPH. Also, when attempting a hard excelleration from a dead stop i get the same vibration until i let up off the gas then it stops. The dealer i bought the car from had the drive train checked out and said the u-joints were fine. Anyone know what this vibration could be? I have the GT4 and GTU options for the rear end.
Old 04-01-2004, 02:31 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: Another Vibration question
check the slipjoint in the driveshaft. theres been a few problems with these they require periodic greasing
Old 04-01-2004, 08:54 PM
Re: Re: Another Vibration question
Thanks, does lowering the truck have that much effect on the driveline?
Thanks
  • 2001 Silverado Extra Cab 2WD 5.3 liter 3/4 drop
  • 2001 Pontiac Bonneville SSEi 180 degree thermostat
  • 1999 Suburban 5.7 4X4 K&N, Hypertech Stat, Hypertech Programmer, true dual exhaust with Flowmaster 50's
  • 1969 Pontiac GTO Judge, Ram Air 3, hideaways, Automatic
Old 04-01-2004, 09:02 PM
tidalcock tidalcock is offline
This is rare, but a cracked flywheel may be the cause. Try pressing the throttle while holding you foot on the brakes. If it happens under this condition, it may be worth a look.
Old 04-01-2004, 10:14 PM
thanks, that would explain alot because the vibration is only there under power. A drive line/ rear end problem would not go away under no power. Since i bought the vehicle used a week ago it is still under warrenty.
Another car stereo question Speculant Car Audio 11 08-18-2010 06:37 PM
woofer vibration question sticks Cavalier 5 07-13-2004 01:12 PM
vibration question Millcreeklord 4Runner/GX470 9 03-01-2004 11:39 AM
Vibration Question (2000 Maxima 5spd) 4 MAX FUN Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 01-05-2003 10:32 AM
Vibration Question (2000 Maxima 5spd) 4 MAX FUN Engineering/ Technical 1 12-29-2002 03:39 PM
