Old 04-01-2004, 12:27 PM
Calstyle92 Calstyle92 is offline
92 RS 3.1 trouble starting
My 1992 RS 3.1L will start and then run perfectly fine, but when I turn it off it won't start again unless I wait for about an hour and a half, longer if it's cold. i checked for spark and there is none, however everything seems to be just fine. Any suggestions?
Old 04-01-2004, 07:39 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: 92 RS 3.1 trouble starting
So its turning over but theres no spark?
or is it not turning over?
Old 04-01-2004, 09:03 PM
It turns over and all. I hooked it up to a scanner and there were no trouble codes, hooked it up to a scope and it was running nearly perfect. Fuel pump is alright, the coil doesn't overheat. It's just when I turn the car off after driving it won't spark again until I wait for an hour or two.
Old 04-01-2004, 09:32 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
check your distributor (if you have one, dont know much about the 3.1) and see if there is any warping on the cap or anything. might want to check the coil after you drive it awhile to see if it has any output. dont know what that would have to do with it, but what the hell, could be fun...
Old 04-02-2004, 12:04 PM
Took off the Distributor cap and the pick coil is fraying. I pretty sure that's the problem.
1991 Cutless supreme 3.1 stalling mandude Cutlass Series 9 02-06-2015 01:16 AM
1990 lumina3.1 Euro starts cold, runs ok until stop engine, then wont restart bigtimmy45 Lumina 1 06-19-2010 12:39 PM
95 Mustang 3.8L-trouble starting... DDP87 Mustang Problem Diagnosis 3 09-27-2009 09:47 AM
'97 3.1 Trouble Starting bugwubber Malibu 6 12-28-2006 03:46 PM
1996 Olds Cutlass Supreme 3.1 trouble starting??? MeanWS6 Cutlass Series 6 06-01-2004 04:12 PM
