2000 Rodeo has no power
I have a 2000 rodeo, just had it in yesterday for 90K service and to fix a broken fan clutch. Driving it home from dealer, it seemed like it had no power. Engine rev's high until I get up to highway speed, seems to hold the gears longer than normal yet not getting any power out of it. Any suggestions?
Re: 2000 Rodeo has no power
When is the last time you had the tranny flushed?
It could be a weak battery, or an alt on the way out. The tranny can do some strange things with a weak battery. -Ryan
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
Trans should have been flushed yesterday as part of 90K service
first time it has been flushed?
Not sure if it is the first time flushed. I have had it in to the dealer for 30K and 60K service, if trans flush is included in those services, then yes it should have been done at least twice prior.
could this have anything to do with the new fan clutch that was installed?
Sounds like your fan clutch is staying engaged all the time. This will zap a ton of power from the engine & make the engine sound like it is roaring loudly. The fan should only engage at low speeds @ higher engine temps.
G/luck Joel
2016 Subaru Forester 2.5i base CVT 2016 Nissan Quest SV Last edited by rodeo02; 04-02-2004 at 07:59 PM. |
It sounds to me like you damaged your powerband. You may need to replace it.
Do it soon!
Took it back to dealer and they said new fan clutch is defective, thanks for your help.
