Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 04-01-2004, 02:32 AM
vsvaz vsvaz is offline
Unhappy Plz Help 1990 Camry Power window problem.
Hi
I Have irritating problem with my windows. They operate once in a while and again they dont. The other day i couldnt close the window fully and my new stereo is stolen. can anybody help.
Thanks
Sean
Old 04-01-2004, 07:33 PM
Joe W Joe W is offline
Re: Plz Help 1990 Camry Power window problem.
For lack of more specific info,the window switch would be the first place to check.Can you duplicate the problem at any time?Is it all of the windows or just one?Sorry about the stereo.
Old 04-01-2004, 08:36 PM
red-in-la red-in-la is offline
Gonna take a wild guess that the electric motor in the window has a spot on the armature or rotor that is burned out. When the motor stops there your s.o.l.
Had a similar thing with another car using pop up headlights and my current '93 Camry.
Good Luck
Old 04-01-2004, 09:00 PM
ice745 ice745 is offline
AF -Advisor
I have a power window problem in my '94 camry, and the design layout should be similar. If your window is still stuck half down, you could take a two wire cable from your car battery, be very careful not to short the wires. Then at the other end, put it to the wire harness on the power window motor (assuming you know how to take off the door panel). You should be able to get the wires to touch part of the metal connector in the harness, its best to use solid wire instead of stranded, or solder the ends of stranded if thats all you have. Putting the Positive battery terminal to the Negative on the window motor, and the negative batter terminal to the positive on the window motor should make it go up. If this does not work, then your motor may be shot. You would then have to dissassemble the motor and regulator so you can manually put up the window and get a replacement motor. In my case one of the wires got broken, this may be another thing to check for if the motor works fine. Depending on your skill level you may want to take it to a trusted auto repair shop and have them do it, but be careful. My problem is about $5 dollars in wire, and probably $100 at most in labor, but one repair shop wanted to charge me over $400 telling me my motor was shot. I laughed in his face knowing that that was not the problem. Its easy to diagnose it, so I would suggest you try to at least diagnose it yourself, so you know what you need done when you bring it to a shop. Or do it completely yourself if your confident enough. If you need anymore details just reply back, I'll be happy to help.
Old 04-02-2004, 02:57 AM
Thanks guys for the suggestions. I went to a mechanic and got it corrected he told me that he installed a new switch and charged $270.
thanks once again.
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 02:44 PM
1990 Mercury Sable power window problems joannslaw Sable 1 05-16-2010 05:25 PM
96 camry power window problem dritalin Camry/Camry Hybrid/Vista 1 09-24-2009 02:09 PM
`99 Power Window Problem.. beadlingi Prism 0 04-27-2009 07:13 PM
1990 Transport Power Window Problem rahengstebeck Trans Sport 2 05-25-2005 08:43 PM
