Old 04-01-2004, 12:33 AM
SikNingStang SikNingStang is offline
Send a message via AIM to SikNingStang
Overloaded MAS??
Whenever I take my 94 GT out to the races and race it a few races back to back it doesn't want to idle. It would run fine but when it comes time for it to idle it'll bog once then die. I took the silencer off of my intake so that's the only thing I figure would cause it but I did that like the day after I got the car so I can't point to it for sure. Is it possible to overload the MAS? I thought it would just be trying to suck so much air while racing that then it wouldn't put enough in the engine to keep it at idle. Anyone else have this problem or know of what might be causing it?
Old 04-01-2004, 10:09 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Overloaded MAS??
Is your car stock or has there been any mods done? Also when you took the MAF sensor out, what did you do to it exactly? You could have possible damaged it. It could also need cleaning. There's many possibilities running though my head right now, can you give a little more detail about your car, about work done to, or what not.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 04-01-2004, 01:18 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Sounds like a bad IAC.... IAC's can cause all sorts of idle problems at all sorts of inconsistent times.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 04-01-2004, 05:04 PM
HiFlow5 0's Avatar
Stanger
Yeah, I was also thinking TPS.
-2013 Ford Flex
-1999 Ford F150
Old 04-01-2004, 05:09 PM
GTStang's Avatar
Stang Guy
Re: Re: Overloaded MAS??
Could be!!! Hence why we run codes. LoL
Old 04-02-2004, 01:54 PM
no everything is stock on it. I didn't take off the MAS I just took the silencer off (the little rubber nose sticking into the fenderwell) so it could suck more air. I talked to one of my friend's today and he said the IAC too. I don't know anything about the IAC so is it something I can fix on my own? Everything is stock besides the K&N Air Filter, X-pipe and 40 series flowmasters.
Old 04-03-2004, 12:31 AM
HiFlow5 0's Avatar
Stanger
I'm wondering if the oil from the K&N has gotten on the filaments of the MAF sensor, causing inaccurate readings. when was that installed, and did the problem start after you removed the silencer?
-2013 Ford Flex
-1999 Ford F150
Old 04-03-2004, 12:55 PM
well, I couldn't tell you if it's b/c I removed the silencer b/c I took that off probably less than a week after I got the car (June 03). The K&N was put in at the same time I removed the silencer. I'm going to race it tonight, I'll see if it does it some more, maybe I'll try removing the air filter or something.
Old 04-03-2004, 09:04 PM
HiFlow5 0's Avatar
Stanger
I'm pretty sure now that oil from the filter has gotten on the filaments of the MAF sensor. You can clean this with a little rubbing alcohol or electronic parts cleaner (something that doesn't leave a residue) on a q-tip. Just be very gentle, because the filaments are very delicate.
-2013 Ford Flex
-1999 Ford F150
Old 04-05-2004, 04:28 PM
Thanks HiFlow
Old 04-05-2004, 07:47 PM
HiFlow5 0's Avatar
Stanger
Don't forget to reset the computer after, so your car can relearn how to idle properly.
-2013 Ford Flex
-1999 Ford F150
Old 04-07-2004, 10:47 PM
^how do you do that?
