Old 03-30-2004, 05:39 PM
beerme beerme is offline
dip stick
i am swaping out a 289 and putting a efi 302 in a 66 mustang, where do i put the new dip stick at im sure i gotta drill in the timing cover but im not sure where i need to drill thanks.
Old 03-30-2004, 05:51 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
eh? timing cover? dunno why you'd have to drill there. should be able to just bring it through the driver-side header. no drilling there, they attach with a bracket that is held by a header bolt.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 03-30-2004, 06:00 PM
Re: dip stick
in a 66 i ran into a problem with the power steering the 93 motor had a rear sump, i put on a front sump now i need a dipstick hole for the front sump pan
Old 03-30-2004, 06:11 PM
hmm... prolly won't have to drill through the timing cover, just route the tube right in front of it, and anchor it with a timing cover bolt. if all goes well it should go right through your belts and sit right in front of your radiator.
although, you should probably try routing it backwards, through the header. that should work perfectly. and you don't have to worry about the stick being so close to the radiator.
-Andy
rust on the transmission dip stick adamantsssssssssss Blazer 2 11-22-2005 02:00 PM
Broken oil level dip stick !!! ai6908 323/Protegé/Familia/Etude/Allegro 0 05-01-2004 10:33 PM
Steam from dip stick 350crazy Camaro Discussions 4 03-09-2004 09:11 PM
Transmission Dip Stick hrpoolgirl21 Grand AM 2 11-13-2003 03:30 PM
blow by in my dip stick bit myk888 '88 - '91 Civic | CRX | Wagon | Shuttlee 8 05-26-2002 03:39 PM
