Old 03-30-2004, 03:57 PM
Bowtie Bandit Bowtie Bandit is offline
accelorator sticking
I have a 2000 Silverado Z71 5.3L. The gas pedal won't go down unless I stomp on it. This is an intermittent problem so it doesn't happen all the time. I saw a post here with the same subject but I can't find it. I remember the problem was fixed by spraying Gumout around the throttle linkage somewhere. Any help would be much appreciated, thanks.
Old 03-30-2004, 04:46 PM
Jimmiz71's Avatar
Jimmiz71 Jimmiz71 is offline
Re: accelorator sticking
There's a Thread posted below by jdugan called Throttle Bodies, there they use 3M cleaner check it out...
Old 03-31-2004, 04:33 PM
jdugan jdugan is offline
Jimmiz is right... you need to clean out the carbon build up on your throttle body. Check out my thread. ~ Throttle Bodies
Old 03-31-2004, 05:05 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Yes, check to see if there is build up. However, I've talked to several mechanics and they all said that a 'sticky' throttle is a common problem on the new chevy's.
*Under Construction - New sig to debut*
Old 03-31-2004, 05:41 PM
yankeeintruder yankeeintruder is offline
I had a sticking accelerator pedal and the dealer installed a new throttle bottle/or parts. That was a couple of months ago at around 30,000 miles.
There was a service bulliten issued concerning this........ don't know the number.
I think I've read somewhere since that GM has revised the service bulliten to: instead of replacement they recommend cleaning first to see if this alleviates the problem. If that doesn't work, then they consider replacement.
I'm going to do the throttle body by-pass.......... I'm thinking that maybe heating the throttle body causes quicker accumulation of residue. Maybe someone who has done this by-pass can comment on how many miles they've gone and if they have had any problems with a build-up.
Old 03-31-2004, 07:07 PM
I have done the bypass... there is no difference. I highly doubt that the sticking is because of a throttle defect. I also have a 2000 5.3, and had the same problem... 45 minutes later it was good as new. Your throttle just needs a good scrubbin'... i am 99.999999999% sure.
Old 03-31-2004, 07:19 PM
tidalcock tidalcock is offline
My 01 extended cab started doing the same thing last week.
I shot some carb cleaner into the throttle body while manually modulating the butterfly valve and that did the trick. Works better than new!
Old 04-09-2004, 03:48 PM
Thanks for the input, I'll try cleaningthe throttle body and let everyone know what happens.
Old 04-09-2004, 06:23 PM
Jeremy-WI Jeremy-WI is offline
http://www.automotiveforums.com/vbul...d.php?t=210522
GMMerlin posted the TSB on this thread
Old 04-12-2004, 09:00 AM
Nigel215's Avatar
Nigel215 Nigel215 is offline
I had the same problem with my 2000 4.8 V8. I just gave it a cleaning and it works great.
Old 05-17-2004, 01:16 PM
I cleaned out the throttle body and now the accelorator depresses with little effort. Big difference!! Only took me about 5 minutes. Thanks for the help everybody.
Old 07-01-2004, 05:21 PM
W88VFR W88VFR is offline
Smile Accelerator pedal sticking
I had a sticking accelerator pedal and it was intermittently worse at times. I searched the threads for the cure, and found this thread. I sprayed carb cleaner into the butterfly area, and generally cleaned the area with a paper towel, using carb cleaner. A small puddle of carb cleaner pooled at the bottom of the butter fly valve, just after spraying. Now the throttle is as smooth as silk!! Thanks for the (even if it is a bit old) input to fix this anoying problem.
2005 BMW Ci Fake Stick Shift TheSixthSin 3 Series 0 05-06-2010 09:13 PM
BIG PROB. engine dies after accelorating undrcroft Accord/TSX/Accord Hybrid 2 09-23-2004 02:25 PM
stutering acceloration (?filter, accelorater pump, carb,?) tmonty211 Blazer 2 07-20-2004 02:46 PM
car sluggish to start and stalls when accelorating Scbaspan82 Fiero 3 04-26-2004 08:21 PM
accelorator pedal sticking tullaroan Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 6 08-20-2003 04:15 PM
