| Let's get Technical! Discussion for hardcore in-depth motor heads! |
Hybrid Transmission: Anything I'm missing before I start?
I currently have a 1989 Honda CRX HF (1839 lbs) with a JDM D15B Vtec (128 hp). At the time of the swap (a few months ago) I was unable to obtain a Si tranny. Just last week I started to hear the whirring and chattering of bearings going out (Input Shaft bearing and probably a few others) Time for a new transmission as the HF tranny isn't worth the $200-$300 worth of new bearings and seals.
This weekend I purchased a ZC tranny (20 spline = 1989-91) which has the closest gearing of any D-Series transmission. I personally don't wish to use the equal-length axles that are required by the ZC transmission... So I'll be swapping in my HF's differential so that I may continue to use the stock axles. (the HF, DX and Si Differential are all the same right? Minus the Ring Gear and bearing sizes) While I have the new tranny broken down, I'll install the HF 5th gear (including the corrosponding counter gear) so that I may keep my highway speed RPM's down (making my long drives much more pleasant) Just thought I'd share my plans with everyone and see if I'm missing anything that needs to be done in order to carry my plans out. -------------------------------------------------------------- -------------------------------------------------------------- Running 185/60/14 (22.74 Inch) Tire/Wheel Combo My Hybrid Transmission ZC 1-4 (1st: 3.250; 2nd: 1.944; 3rd: 1.346; 4th: 1.033) HF 5 (5th: 0.694) ZC Final Drive (Final: 3.88 ) Data shown with redlining @ 7200rpm GEAR MPH RANGE (RPM SHIFT RANGE) 1st: 0 - 38.64 (idle - 7200) 2nd: 38.64 - 64.60 (4306 - 7200) 3rd: 64.60 - 93.31 (4985 - 7200) 4th: 93.31 - 121.58 (5526 - 7200) 5th: 121.58 - 180.96 (4837 - 7200) 5th @ 80mph: 3183 rpm ZC 5th Gear @ 80mph would be 4027 rpm! ---------------------------------------- ---------------------------------------- Things to do: --Replace all bearings and seals -There's a difference in the bearing sizes Countershaft bearing (30x47x21 = HF; 30x55x21 = Si) Mainshaft bearing (6205UC/26 = HF; 6305SPL = Si) Differential Oil Seal (35x56x8 = HF; 40x56x8 = Si) Speedometer Drive Gears have different part numbers between HF and Si The transmission cases are of course different part numbers because the bearings are different sizes. Since the only sizing that is different is one dimension, can I use either size bearings on the HF differential? If I can use either size bearing on the HF Differential and ZC Main/Countershafts then I can use either case (ZC or HF) I want right? Just pick the bearings that match the casing? --Swap in HF 5th gear and counter gear --Swap in the HF Differential -I am required to re-shim the differential upon bearing replacement right? -Since I'm using the ZC Countershaft (part of Final Drive) I need to swap on the ZC ring gear onto the HF Differential correct? Is that all that the "final gear" consists of? I've been searching every Honda/Acura website I can find as well as Google etc to gather as much info as I can. The above questions still remained somewhat unanswered to me from what I've found. Thanks you for any help you may give. John (BlueCrxNC) [email protected]
1990 Honda Civic STD Hatchback R.I.P. 11/2/2006->> 1989 Honda CRX HF - 253K Miles |
You seem pretty damn knowledgeable about trannys so i got a question or two:
First off, are ALL d series gear interchangeable? As in you could mix and match between dx, hf, and si gearing? Are there non-aftermarket LSD d series transmissions? Lastly, are gears from different transmissions (trims) different strengths? Thanks! btw-where are you in NC...Im johnston county...yee haw....
I'm Alex. A cookie to whoever guesses what car I'll get! ![]() I tend to hate people....expecially liberals... This is my temporary racecar-the two liter beast itself, the 87 camry:
Re: Hybrid Transmission: Anything I'm missing before I start?
PunkAlex, I would only see myself as a good researcher Now with computers I'm very knowledgeable and everything that I know about computers is self-learned (Even the hard way [ie. When I was 12-13 yrs old I literally opened up a hard drive to see what was inside... I had no idea that doing so would render the drive useless ])I do believe that all D-series gears are interchangeable (unless it goes by the clutch type; cable vs hydro), allowing you to do as I am; Making the best from what the factory has to offer. Your chances of finding the elusive D-series LSD tranny are worse than slim to none. It'd be like winning the lottery There are LSD ZC's and then there are LSD trannies from the JDM D15B Vtec (the motor I have; but they are hydro, if that makes any difference)Oh, and I'm located in Greensboro, NC (Guilford County) but travel to Charlotte often (soon to move to Charlotte) When I get my transmission done, maybe I work something out so we can meet up. [email protected] -> John Strickland
