Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-29-2004, 06:35 PM
PAULsr1972 PAULsr1972 is offline
Question 1998 Toyota Camry Struts
How Hard Is It To Do Struts (front And Back) On A 98 Camry?
Old 03-31-2004, 05:55 PM
nmikmik nmikmik is offline
Question r u sure you need em
Here is part of the post from FREDBROS72, yhou cazn find other posts if you do a search of this forum on 'strut'
struts,
too save money , you can take struts out yourself, better off , taking struts too shop and have swap over, most of money is labor too remove, can do it yourself, but can be tricky, front or rear struts,
usually do not have to replace upper mounts, sometimes bearings go in mounts , but most of the time ok, usually if leaking , want to replace boots, bumpers, and lower cushions, most rubber accessories, taking out the struts is pretty self explanatory, three small nuts on top, not the center one, two large nuts and bolts through hub,
Old 03-31-2004, 09:58 PM
red-in-la red-in-la is offline
Re: 1998 Toyota Camry Struts
Get a good spring compressor, jack, jack stands. It's time consuming. I did mine in my Miata and Neon with my son.
Hardest part in Camry is finding upper attaching nut under the parcel shelf.
For sure, get new boots. Don't know about bumpers. Bumpers are usually come attatched to the boots, but if u get "universal" boots the bumpers might not be there or fit.
Good luck.
1998 Toyota Starlet Sportif (white) sjtilley Classifieds 0 04-13-2009 11:13 AM
valet switch for 1998 toyota Camry hard2000 Camry/Camry Hybrid/Vista 1 07-07-2008 12:44 PM
1998 Toyota Camry Owner's/Repair Manual usua_ie Camry/Camry Hybrid/Vista 2 03-28-2006 09:27 AM
stereo install 1998 toyota camry VicRockk69 Car Audio 3 05-12-2004 07:00 AM
