Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-28-2004, 05:13 PM
trainman trainman is offline
Question 98 Ram tranny problem?
I have a 98 Ram 1500 Quad Cab 4x4 with 62,000 miles on it that is making a strange noise and vibration, sounds like someone is bouncing a basketball on the floor of the truck. The noise and vibration starts at 45 mph and will stop if I accelerate or remove my foot from the gas pedal. The noise and vibration has also happened at 55 & 65 mph.The trans does shift smoothly like it always has.This happens with the cruise on or off and with the overdrive turned on or off.
Thanks
Don
Old 03-29-2004, 02:09 AM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: 98 Ram tranny problem?
Doesn't sound like the transmission is responsible.
Did you check under the truck to see if you've got something hanging under there that shouldn't be?
Old 04-02-2004, 05:32 PM
I checked under the truck before I submitted the problem and found nothing loose or out of the ordinary .
Old 04-05-2004, 05:50 AM
malcolm brumley malcolm brumley is offline
I had a 2001 pu with a similar vibration and noise. When I finally found it it was a bent drive shaft. It was not bent very much. I didn't even see it when I had it up on jacks running in gear the first time, but the second time I did.
macbrum
Old 07-08-2004, 12:57 PM
I have checked under the truck and nothing is loose, bent, or broken. This problems always happens when going up hill.
Old 08-13-2004, 07:10 PM
kevin032 kevin032 is offline
may need to replace your u joints
1999 Ram tranny problems Brewski3 Ram Pickup | Ram SRT10 1 10-26-2004 01:57 PM
97 Dodge Ram Tranny Problem LTJGWorth Ram Pickup | Ram SRT10 6 06-27-2004 03:45 PM
