Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 03-28-2004, 04:14 PM
2many? 2many? is offline
Newbie questions - 95 Monte LS
Hello all,
I have 2 questions on 95 Monte.
1. I have turn signal that will not hold in position. The signal lights up but the turn signal stalk will not stay, do I need a new switch? If so, does it require special tool to remove the steering are so that I can change it?
2. My speedometer works on and off. Sometimes it will not work and for a few months, no problem. Has any one had this trouble? It sounds like ground iss but which ground wires?
Thanks in advance for your help.
Steve
Old 04-11-2004, 03:45 PM
nycemsmedic nycemsmedic is offline
Send a message via AIM to nycemsmedic
Re: Newbie questions - 95 Monte LS
Yes you will need a steering wheel puller..if you are really cheep you can remove the air bag n loosen the nut and pull real hard cocking the wheel slightly. i do not recomend this!!!! then you will need to remove the plate that is next. to do this there is a tool that screws on the shaft where you removed the steering wheel nut. then tighten the tool and it will push that plate down. remove the lock ring and remove the plate. just rip it off cus you can replace that ring for a few cents. then you can get to the signal switch.pull out the directional handel from the column and remove the switch. its been a while since i did this, but this should be able to get u started. Dave
Still a newbie and have a newbie question JeenyusVR4 3000GT/Stealth 2 03-10-2007 09:03 PM
I'm a newbie....and I have a few newbie questions missmarissa '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 02-17-2004 06:40 PM
hi guys newbie here ... with not too newbie questions um i think 180sx-dude Engine 5 02-04-2002 05:00 AM
Newbie question about priming Mikke Car Modeling 12 11-26-2001 09:43 PM
Newbie Questions Arsn General Discussion 17 11-20-2001 03:00 AM
