Go Back   Automotive Forums Car Chat > Volkswagen > Passat
Old 03-28-2004, 03:01 PM
gx3man gx3man is offline
Passat revving up when shifting
My wife and I just bought a '99 Passat, V6, with a manual. It runs great except for one strange thing I noticed. When upshifting the engine tends to rev up a bit, especially between the lower gears. It also takes quite a few seconds to drop the revs. This makes it a pain when upshifting, as it tends to jerk unless you hold the clutch in until the revs drop off. If anyone has any experience with this and could shed some light it would be much appreciated.
Old 03-28-2004, 03:34 PM
DaviX's Avatar
DaviX DaviX is offline
Send a message via ICQ to DaviX
Re: Passat revving up when shifting
could be your step motor
or one of the sensors. wanna get them checked with a VAG computer.
Not quite sure though, David.
Old 03-28-2004, 05:39 PM
boschmann boschmann is offline
I've heard many people have had success solving a variey of symptoms with a good cleaning of the throttle valve, seems alot of dirt builds up in there. Just don't disconnect it electrically as if you do you will have to re-adapt it to the ECM with a VAG or similar scan tool. Some just remove the rubber air pipe & clean with a toothbrush & FI/throttle body cleaner, others remove it from the throttle body to get better access.
04 impala Shifts Hard when Hot, P1811,shifts hard,jerks chevymandan Impala | Impala SS 3 10-09-2011 04:42 PM
Stalls when revved to over 3K rpm jkoch53102 MPV 2 12-19-2010 08:14 PM
Revving when clutch in cooneyjason13 SC/SL/SW 3 11-11-2008 11:10 AM
constant revving when cold hunterfuqua Accord/TSX/Accord Hybrid 1 03-05-2008 04:51 PM
Engine revving when turbo kicks in Judson MR2/MR-S 4 02-04-2005 02:05 AM
