Old 03-27-2004, 10:54 PM
Babs007 Babs007 is offline
Unhappy 97 Escort acceleration
I just had total exhaust system and muffler replaced. I am noticing its hard to accelerate on hiway and maintain speed. Could this be a problem with the size of pipe or muffler? Seems like there is an obstruction in the exhaust and motor seems to be overworking. Any help appreciated.
Babs
Old 03-31-2004, 03:52 PM
Ralph Marontate Ralph Marontate is offline
Check this out. I HAD A PROBLEM WITH THE ACCELERATION OF MY ESCORT WAGON. AFTER MUCH GRIEF I FOUND OUT THE VIBRATION DAMPER PULLEY HAS A RUBBER INSERT THAT, WHEN WORN, ALLOWS THE DAMPER PULLEYS TO ROTATE SLIGHTLY.
THIS CHANGES THE TIMING POINT ON THE PULLEY AND THAT TELLS THE CRANKSHAFT POSITION SENSOR THAT THE ENGINE IS ADVANCED SO THE COMPUTER RESPONSES BY RETARDING THE IGNITION TIMING RESULTING IN NO OR LONG DRAWN OUT ACCELERATION.
Check out the damper before you start shot gunning parts into the engine.
Old 03-31-2004, 07:56 PM
Team otr Team otr is offline
Send a message via AIM to Team otr
Re: 97 Escort acceleration
Yeah, I had the same bs happen to me. Then I found out if you remove the pulley intirely and buy a smaller belt to fit it with one less pulley,and reset the ecu you will get 7-13 extra hp at the wheels depending on mods already done.
Old 04-01-2004, 11:21 AM
noobie noobie is offline
is back pressure a big thing with the escort?? if it is you might not have enought back pressure for the motor. (happend to my friend with his explorer)
Escort accelerates by itself chrisanthony Escort 3 12-06-2009 08:03 PM
Escort 99 keeps jumping on first drive of day for about 150 Yards (CEL 0401) MyEscort99 Escort 4 04-02-2009 11:11 AM
Loses power under acceleration MikeS144 Metro 13 02-15-2009 07:56 PM
91 Escort Acceleration Click Flyingwhitey Escort 13 05-01-2008 03:04 PM
97 Escort acceleration problem ellerdonanc Escort 2 06-04-2004 11:13 PM
