Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 03-27-2004, 09:01 PM
wordyo wordyo is offline
'94 Explorer Acceleration
I drive a '94 Explorer V6 4.0 Liter. It has just over 80,000 miles on it and has had no need for major repairs besides the brakes.
The problem is when I go to punch the gas, it lags for 1 to 2 seconds before the engine kicks in. Also, when I put it in neutral and rev up the engine won't exceed 3,000 RPM. The indicator says it should be able to go up to 5,000 but it just won't. It stops just past the 3,000 RPM mark and begins to putt.
I took apart the catylac converter today and tried it without anything on it to see if that may have been the problem. No dice.
I changed the fuel filter, no difference. Then I checked the fuel line for leaks, no luck there either.
Any ideas?
Old 03-28-2004, 03:53 PM
Opera House Opera House is offline
Re: '94 Explorer Acceleration
First, it has a rev limiter and it will never go over 3K unless you are driving it. I would check the vacuum line that goes to the pressure regulator to see if that is off or has a hole in it. When the regulator sees a drop in vacuum indicating demand, it boosts fuel pressure to richen the mixture. If you have never cleaned your MAF sensor that could cause it. The TPS could be worn in a spot so the computer doesn't see the demand. Fuel pump may be worn so it can't produce the needed pressure. Normally about 80% of the fuel goes back to the tank so this isn't usually a problem. EGR may be sticking open.
Old 06-28-2004, 09:14 PM
homie774899 homie774899 is offline
Sorry If I Bring No Help To Your Qeution, But There Is No Rev Limiter At 3k Rpm's You Can Even Go Past 5k. Ive Had A Little Fun Reving Against Other Cars At The Stop Lights.
'94 Explorer engine smoking Explorer94 Explorer | Explorer Sport Trac 3 12-22-2005 01:53 AM
'94 Explorer EB Interior lights stay on, Alarm? KillerMule Explorer | Explorer Sport Trac 4 12-06-2005 07:16 PM
'94 Explorer electrical Q T2bcristlk Explorer | Explorer Sport Trac 3 01-27-2005 09:42 PM
Thermastat location '94 Explorer Explorer94 Explorer | Explorer Sport Trac 1 01-24-2005 10:27 AM
'94 SL1 Acceleration problem Aleks SC/SL/SW 16 10-13-2004 10:17 AM
