Old 03-24-2004, 08:23 PM
98-ls 98-ls is offline
crower 404's
to put in 404's, crowers web site it requires an ecu mod , what is this and do i really need it?
Old 03-24-2004, 09:54 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: crower 404's
You posted this on Honda-tech right
Well yes it is best to have hondata or something of the sort. Alot of people use a safc to do the trick. The most important thing with these cams is to get the valve springs. Get the crower springs, don't buy any other brand spring! Also you will want to consider putting in some higher compression pistons too, they are not a must have for the cams to work but if you want all that they are capable of then yoiu need them. I have the same cams an d I think they are great, they are not nearly as crazy as most people make them out to be. For the short time I had them installed they idled great, almost stock even.
Crower Cams PoisonFangs Engineering/ Technical 3 05-19-2002 01:30 PM
Crower Cams BoosterSH Prelude 4 03-07-2002 05:11 AM
crower cams and turbo big blue h22 Forced Induction 2 02-23-2002 10:23 PM
turbo prep...Crower Cams & Pistons? clatescivicr Engineering/ Technical 3 01-27-2002 02:22 AM
Analysis of H22 Crower Cam Specs fritz_269 Prelude 0 12-05-2001 03:12 PM
