Old 03-24-2004, 07:40 PM
top_down_camaro's Avatar
top_down_camaro top_down_camaro is offline
Inaccurate RPM reading
Has anyone seen this before, I just recently replaced my computer and chip (Hypertech). Now i noticed my RPM's way off the charts. Idle's around 1,250. (Normal) but noticed when i kicked it down it was up around 7-8K when i was jumpin on the highway. Now this is a stock motor so there is no way this is accurate.
Plus when it is rev'd up a tade, reads 4K ( for an example ) but sounds as if its 2K. Hardly even stroken. Other then that the car runs excellent
Old 03-24-2004, 07:54 PM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
Re: Inaccurate RPM reading
probably the computer or the chip then. the rpms are read from the coil, but I don't believe that would be the problem. Where did you get your computer and chip at? I'd see if you could exchange them.
Old 03-24-2004, 08:03 PM
Dont think its neither, ran the stock chip untill my hypertech came in and was the same. Besides since i have replaced the computer alone,(previous issue) the car runs better then it ever has and better yet with Hypertech chip, only complaints i have is pumping 93+ oc fuel wich can hinder the wallet but has the same millage. Baiscly very happy with the performance, just thought it was odd seeing the RPM's off.
Old 03-24-2004, 08:06 PM
when did the rpm issue start?
Old 03-24-2004, 08:16 PM
Honestly, didnt notice it untill the other day, But when i was having issues with idle/richness before i replaced the ECM is when i noticed the RPM's reading higher then what they really where. Now the idle is normal but when kicked down there in accurate. Was thinking switching over to a higher spark coil. It still seems to ping with 93 oct.
k1500 rpm go up when driving garftree Sierra 2 08-22-2010 08:08 PM
98 jetta 2.0 M/T stalls 3500-4200 RPM pulling hair '97 - '03 3 03-20-2009 02:56 AM
91 Camaro RS V8 - Inaccurate RPM readings on tach Relik00 Camaro Discussions 16 06-24-2005 10:28 AM
rpm reading problems snowman2005 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 02-13-2004 08:13 PM
RPM Reading Problem ychan 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 0 10-13-2003 02:13 AM
