Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 03-24-2004, 06:38 PM
Russstang Russstang is offline
Angry Engine trouble with daughter's 97 SC2
PLEASE....someone help me, I'm at my wit's end. My story in brief. Daughter is in college, she bought a 97 SC2, engine threw a rod, garage installed a 50,000+ engine in it.....then the engine problems began after about a year. The engine will "surge" or "miss" or "skip". This becomes pretty bad at times and gives "misfire" codes, etc. We've had the codes read an had a garage AND a Saturn dealership replace the following:
Plugs/wires/coils/valve cover gasket/coolant temp sensor/engine temp sensor/O2 sensor in manifold/fuel pump/cleaned injectors and valves. Some of these things have been replaced twice already, but it will still skip after awhile and give O2 codes and multiple misfires.
What gives???????? Why can't the Saturn place fix my car? What can they possibly be missing? My daughter goes back to school soon and we've sunk over a grand in it to no avail. After their last round of replacements, the car unloaded a ton of carbon buildup and ran better for awhile, but then it started misbehaving ALL OVER AGAIN!! I'm begging you, help me out.....
Old 03-30-2004, 06:45 PM
MBCaprice MBCaprice is offline
Re: Engine trouble with daughter's 97 SC2
Replace the O2 sensors.
Old 04-12-2004, 10:57 PM
kicknbutts kicknbutts is offline
the pintle in the EGR valve is probably at fault. This is probably sticking causing tps to go slightly out of range fouling the O2 sensors.
Good luck........p.s try a diff saturn dealer.
Old 04-16-2004, 07:15 PM
SC-Xtc SC-Xtc is offline
Also could be a clogged Catalitic converter, like a domino effect.
Just bought - need a new engine, help! Kaeldra1 Focus | C Max 1 06-20-2010 07:43 AM
95 sc2 motor swap with 99 sc2? cmar0951 SC/SL/SW 1 09-12-2009 11:14 AM
Tahoe trouble combat.medic06 Tahoe 2 07-14-2009 08:27 AM
92 sc2 vaccuum leak? bmowery SC/SL/SW 5 04-20-2009 01:34 PM
Engine Trouble With 2.5 L S10_mod_beginner S-10 3 11-21-2004 11:58 PM
