Old 03-24-2004, 02:48 PM
Fox_Rocks Fox_Rocks is offline
Rear Posi Stuck
Hey everyone, I was wondering if anyone knows anything about the rear posi trac axles on a 91 chevy S-10, it is the Eaton posi unit and it is stuck in the Posi position, my tires chirp around the corners and it had a major push on the front when turning...anyways i have had the pot off and nothing appears to be broken , and i assume it is the clutch packs that are giving me the trouble...but they normally break so that posi doesn't work, not so it stays locked.....anyhow if anyone has had this happen in the past and can help it it would be greatly appreciated. Thank you for your help in advance.
Fox
1991 Chevy S-10 Ext. Cab
4X4, 4.3L TBI V6.
-Competition Camshaft, Ported Heads, Bored .40 Over,
Completely Rebuilt (everything), Roller Lifters, K&N Filter,
MSD Wires, Jet Performance Chip, B&M Shift Kit,
AirRaid TBI Spacer, 3:42 Posi Trac, 2" Lift,
American Racing Wheels, BFG All Terrain Tires
Old 03-24-2004, 03:32 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: Rear Posi Stuck
try adding some posi friction modifier
Old 03-24-2004, 06:03 PM
yeah i forgot to mention that when i had the pot off, and put it back on, i filled it with new gear oil and that GM friction modifier (AKA whale oil), but thanks anyways. Peace
1975 Caprice rear end gear/rear end swap? Topless75 Caprice 3 03-10-2010 12:29 PM
Rear end noise fastlane85023 Mustang Problem Diagnosis 4 11-29-2009 07:39 PM
Rear Air Shocks stuck fully extended phantomyj Silhouette 1 10-09-2009 03:54 PM
determine posi for 88 caprice youngwit88caprice Caprice 0 04-24-2009 03:58 PM
Rear Brakes Stuck on! Jimmy98 Jimmy 2 06-11-2004 10:00 AM
