Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-23-2004, 04:01 PM
ouchie1 ouchie1 is offline
2001 rodeo check trans and cruise set light
I have a 2001 rodeo my check trans and cruise set light come on when I am driving, But the lights only stay on for a few seconds. The transmission shifts different when these light come on for a few seconds. I have taken it to 2 dealerships and they are unable to catch this error. Sometimes the truck will shut down or the lights come on, truck shifts different, lights go off , truck rides fine.
What can I do?
Old 03-23-2004, 08:32 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 2001 rodeo check trans and cruise set light
Isuzu's do some strange things, when they have a weak battery, bad body grounds from the battery, or an alt that is putting out to much or to little juice.
You could also have a wire somewhere in the wiring harness that has rub through at some point or an animal decided to dine on it.
Check my FAQ's below for more general maintance issues for your Isuzu.
-Ryan
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-24-2004, 09:48 AM
Isuzu Guy
http://forums.vmag.com/suvrodeo0300/messages/2803.html
Could be a bad trottle position sensor.
-Ryan
Isuzu Moderator
Car Show Tips
Old 03-24-2004, 02:20 PM
rodeo02 rodeo02 is offline
ouchie- when the trans acts up on you, does the "PRND321" indicator lights in dash cluster indicate the same gear you have selected from the console shifter? Kick it down into "3" when it acts up & see if the dash goes to "3". If it doesn't this could be a faulty trans range / mode sensor. These things cause the tranny to go whacky when they dont get a good signal.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 01-29-2006, 08:27 AM
jetset45 jetset45 is offline
I have the same problem, except I have a 2000 Rodeo..."The check trans and cruise set light come on when I am driving, But the lights only stay on for a few seconds. The transmission shifts different when these light come on for a few seconds. Sometimes the truck will shut down or the lights come on, truck shifts different, lights go off , truck rides fine".
Help!
Old 11-21-2008, 10:38 AM
foghatch foghatch is offline
Did you ever get this problem fixed? I have a 2002 Rodeo that the same thing is happening. It would be great to know what worked. I have had the throttle body changed, a sensor in the pedal changed and the dealership wanted to change the EGR for $600. If you can help it would be great.
Check Transmission and Cruise set light come on. foghatch Rodeo | Passport | MU 1 11-16-2010 06:22 PM
2000 Rodeo..Trans light and Cruise set light / Engine Shutdown jetset45 Rodeo | Passport | MU 19 06-20-2010 12:03 PM
1993 Trooper Check Trans Light Chay Trooper | SLX | Bighorn | Wizard 0 03-23-2009 05:05 PM
Check Trans light comes on together with Cruise Set light weathermedic Rodeo | Passport | MU 1 07-27-2007 09:24 PM
2001 Solara Check engine and trac control light on jasjfarrell Solara 1 02-28-2005 02:11 AM
