Old 03-23-2004, 03:29 PM
Verloren Verloren is offline
'91 c1500 Fuel System Problems - Injectors don't Inject/Won't Start
I've got a '91 1500 and it won't start. It appears that the fuel injectors aren't getting any power. It's a TBI setup with the v6.
Here's what I've done and how I got to the point where I believe there is no power to the injectors.
1. Tested/listenend to the fuel pump. Sounds fine.
2. Replaced the inline filter.
3. Disconected the fuel line from the TBI and cranked the engine over. Sprayed gas all over.
4. Checked fuses. All ok.
5. Assuming the relay is ok since the fuel pump sounds fine.
6. Used a multimeter to check the resistance of the injectors and both have the same reading.
7. Used the multimeter to check for DC voltage in the electrical connection to the injector and it reads 0. Maybe I'm doing it wrong?
The battery is 3 months old, plenty off power. The engine turns and turns but there isn't any fuel coming from the injectors.
Not sure what to check next. Any advise is greatly appreciated.
Old 03-23-2004, 06:41 PM
michelq michelq is offline
Re: Fuel System Problems - Injectors don't Inject
If no power to injectors you may have blown fuse bad connection in fuse box.some times you a test light to check system.
check two 10 amp fuses in fuse box it said injectors
Old 03-23-2004, 07:58 PM
I checked the fuse and it wasn't blown.
Old 03-23-2004, 10:54 PM
pind pind is offline
replace your ignition module, it is not givig a reference signal to the ECM, hence the ecm is not telling when to fire the injectors. This is a common problem. and yes, it sucks. been there, done that, bought the t-shirt. sold it with the truck.
Old 03-24-2004, 04:00 PM
Thanks pind, worked like a charm.
Old 04-04-2004, 07:34 AM
holy i would check oil sending unit wires and rear wiring harness under driver side carpet
Old 04-04-2004, 10:14 PM
you have something that is shorting to ground when you start the vehicle. that is what they have to do with the problem. Check all leads that are "hot" when the engine is running
Old 04-05-2004, 12:20 AM
jay hullett jay hullett is offline
also ck egr and purge solenoids pink or pink black wires for rubbing bracket real problem on full size trucks if happens after a recent repair also look at injector wires at throttle body can get pinched where breather set on throttle body
Old 04-06-2004, 08:05 PM
ooookkkk, obviously i was born stupid. Find a wiring diagram. Locate all wires that are hot when the key is in the run position. the engine does not have to be running to do this. Its an electrical problem, not a mechanical one.
When you locate all of these wires, which are all over the place, check them all for tight spots, and insulation that has been rubbed through, allowing a path for power to short directly to ground.
Hopefully this clears it up a bit.
Old 04-08-2004, 06:34 AM
Re: Re: Re: Fuel System Problems - Injectors don't Inject
Originally Posted by holysmokesareforre
i'll check them but whats oil sending unit got to do with this ?please answer
THE fuel pump control by the oil sending unit
Old 04-13-2004, 04:53 AM
check your crank sensor in dist
Old 04-13-2004, 08:15 PM
holysmokesareforre holysmokesareforre is offline
is this about cavalier or dodge lolo?
1999 Jetta GLS 2.0 AEG Fuel system problem Probe '97 - '03 3 04-20-2010 10:24 PM
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 08:35 PM
Fuel system and injector tune up? blazzingbrandon 4Runner/GX470 2 03-16-2005 08:44 PM
FUel system problem jhambrick Altima 0 10-21-2003 06:08 PM
Won't Start - Fuel System Problem? 63craig C/K 1 10-10-2003 12:26 PM
