Old 03-23-2004, 02:40 PM
hellbender23 hellbender23 is offline
Exclamation 88 F150 Will not start
I have a 1988 Ford F150 with a 4.9L 300ci motor, here is the problem, I was driving to work and the engine just quit. I tried to get it started again, but it would not. I pulled it home and checked the fuel pump to see if it was running because I could not hear it running, and it was not. So… I replaced the fuel pump and filter. It ran great for about 4 days. And once again the motor cut off out of the blue. Now I have check the fuel pump to make sure it was still working and it was, in fact it had great pressure. I have pulled the spark plugs to see if it had fire, and I did. I know its getting fuel to the motor because it will fire the motor off for about 3 sec. every once and a while, and will not start again. I am at a loss. Thanks for the help.
Old 03-24-2004, 09:02 PM
pete54ford pete54ford is offline
Send a message via Yahoo to pete54ford
Re: 88 F150 Will not start
How does it sound when you turn it over? Does it "fight" its self? Not sure not being there, but I wonder about the timing.....or maybe your pump is weak and has just enough umph to get some gas it to it. Dont really know....sorry but good luck!
Old 03-29-2004, 02:25 PM
No the motor turns over good, but every once in while it sound like it’s just about to start but doesn’t. Like I said before, I was driving the truck and it just died out of the blue, almost like I had turned the key off. I have checked the spark plugs and they are firing off, and the engine is getting fuel, new fuel pump.
Old 03-30-2004, 01:17 AM
amac209 amac209 is offline
Send a message via MSN to amac209
double check all the wiring to the fuel pumps and the relay. i think it's located behind the glovebox somewhere on your truck. also check the relay wiring ford wiring is famous for corroding and causing a voltage drop. you can jump the fuel pump from the eec conector i don't remember which terminal it is but a good manual should help you out. good luck. oh yeah check the inertia switch too it's located up by the brake pedal somewhere.
Old 05-02-2004, 08:41 PM
Tesha Tesha is offline
Hell... i was wondering if you have figured out this 'fuel problem'. I also was driving last week and my truck turned off. I checked and replaced everything, including the fuel pump twice. I've checked all the wiring, there is power running everywhere it needs to. It almost appears there is a MASTER reset smitch somewhere. After about 600.00 in new parts, im bashing my head on a wall. Let me know.
Old 05-17-2004, 12:45 PM
VinceRouse VinceRouse is offline
Tesha,
I am not sure what year vehicle you have. I have a '92 F150 and yes there is a master switch. On a 92 F150xlt it is behind the cowl on the passenger side (If you are sitting in the passenger seat it is closest to your right foot). There is a red button. It says right on the engine that this breaker is intended to prevent fuel leaking in an accident. It says that it can be triggered just by hitting a pot hole. (Seems silly to me, but there you have it. )
-Vince
Old 05-17-2004, 12:51 PM
A pot hole??? I have never had that happen to me and I use it for "field" fence checks. But I guess....anyway, check your dist. cap and your rotar. My 1986 f150 just did the same, and thats what it was, I to was checking fuel pumps and everything else related to the fuel. But good luck!!
Will not start (sort-of randomly) caffeineaholic Caprice 7 08-04-2010 08:13 PM
2001 ford f150 will not start anti theft rachelh19 F Series 0 03-27-2007 02:14 PM
F150 Will Not Start, Please Help gkiril F Series 2 05-25-2006 10:33 PM
'91 F150 Will NOT Start When Humid nuttybar00 F Series 1 02-22-2006 02:03 PM
95 F150 will not start gaston bob F Series 1 09-01-2004 11:05 PM
