Old 03-23-2004, 02:33 PM
saltyfrog saltyfrog is offline
front end vibration/wobble
I got a 2000 Silverado 2500 4x4, 6 liter engine, 4l80E trans, with about 90K miles on it. Lately it has developed a front end vibration that I'm suspecting is turning into a wobble. Driving it I can hear it but I don't feel it. The vibration/wobble increases with speed. I've had it aligned and my tires balanced. I've also checked the tie rod ends, pitman arm, and idler arm and they are all fine. There are small leaks in the front diff seals but it hasn't run dry. (I filled about 3/4 quart last night). There is some play in the axles which I'm guessing is causing the vibration/wobble, how much play is normal? I'd appretiate any ideas on how to solve this problem, it's really getting annoying.
Thanks in advance.
Old 03-23-2004, 03:53 PM
Miller52 Miller52 is offline
When you step on your brakes if it pulses in and out it might be that your front rotors are warpped and that could be your problem causing vibration.
Old 03-23-2004, 05:03 PM
If anything stepping on the brakes makes it vibrate less. It also seem to vibrate less when I'm turning. I'm considering having my alignment checked again somewhere else.
Old 03-23-2004, 07:07 PM
Slowprocess's Avatar
Slowprocess Slowprocess is offline
Send a message via Yahoo to Slowprocess
Have you checked the wheel bearings? Mine started doing that, and I found out the wheel bearing had went out.
Daily Driver- 00 Camaro SS A4 1/4- 12.30@118mph 2.14-60ft on street tires
Weekend Warrior-99 Silverado "Dirty" 1/4-11.63@118mph 1.8-60ft
Old 03-24-2004, 08:34 AM
There is some play in the wheel axle on both sides of the diff, is there a good way to check the bearing w/o pulling the axle? How much play is normal?
Creaking Noise At Front-End el ratfink Pacifica 2 12-05-2009 11:57 AM
Front end noise Bob Moore Dakota 5 07-25-2009 04:40 PM
Vibration at high speeds uspres2020 Grand AM 4 07-19-2009 06:23 PM
Front End Metallic Clunking amesjm0431 Grand Prix 2 06-17-2009 09:17 PM
Wobbling front end das_kuppler Ram Pickup | Ram SRT10 3 03-07-2009 03:17 PM
