Old 03-23-2004, 12:28 PM
crxhf19 crxhf19 is offline
B18a1/VTEC conversion
i am currently in the process of building a ls/vtech conversion. I an building the bottom end with eagle h-beam rods(good up to 600 hp) and forged wiseco pistons with wiseco rings with a compression rating of 9.2. i went low on compression because i am going to put a turbo on it and once im done with the bottom end i am going to be done with it. I dont want to have to tear it back down because i fried some rings or blew a hole in my piston. any ways i am going to put a vtec head on it and i was wondering what head you would put on the motor. i am going between b16 or b18c1. also what year of these heads do i need to put on my block(i want to have to do as little wiring as possible) thanks
Old 03-23-2004, 03:59 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
I would go with a B16 head for better commpression, I am guessing the 88-91 1st gen B16 head would be the best as for wiring
KoRnSaQ
Old 03-23-2004, 04:19 PM
SiZ's Avatar
SiZ SiZ is offline
Re: B18a1/VTEC conversion
If you're building for boost and you've got pistons and rods I wouldn't even waste the time and money on a VTEC head. Just get a good fuel managment system and run high boost.
"The nympho of info, I'm fuckin' what ya heard"
Old 03-23-2004, 10:57 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Why a B16 head for better compression? The GSR head will yield a higher compression ratio. Unless of course you meant, go with b16 because it will keep the compression low.
B18B1 Vtec Conversion Ntegra Dryvr Engineering/ Technical 13 03-02-2010 06:15 PM
LS VTEC conversion Racincc85 Integra 12 02-13-2004 01:03 AM
h23/vtec conversion? redleaf786 Prelude 10 01-26-2004 04:17 PM
JDM Honda Parts.com P14 VTEC conversion crj_lll Prelude 0 08-03-2003 04:22 AM
