Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 03-23-2004, 10:14 AM
msteele msteele is offline
Question Help Suspension\Tire problems
My 1996 Civic has been having problems...
When i reach about 65 mph the car will start to rumble... I had the wheels balanced to see if it would fix the problem but no luck...
Periodically the rumble will go away if I hit a bump in the road or a transition from asphalt to concrete...
History:
* 112,000 miles
* Yes 4 wheel balance was done
* The tire where the rumbling appears to be coming from was patched
Could this be suspension?
Could there be a piece of loose patch in the tire?
Bent rim?
Thanks,
Old 03-23-2004, 11:21 AM
marchi1's Avatar
marchi1 marchi1 is offline
Send a message via MSN to marchi1 Send a message via Yahoo to marchi1
Re: Help Suspension\Tire problems
I had a similar prolem on my old Cavalier. someone had put the liquid tire sealer inside the tire, and when the car sat for a while it semicured. We ended up demounting the tire, and cleaning it all out, and then correctly patching the tire.
Old 03-31-2004, 09:47 AM
Grant@Tirerack's Avatar
Grant@Tirerack Grant@Tirerack is offline
Exclamation
That could be any number of things. If it is on the same corner where the patched tire is, I'd have the tire pulled off the wheel and inspected. You may have a failure in the patched area of the tire. If it were a bent wheel the vibration would be fairly constant and would not come and go. If the interior of the tire starts to break down, it may be causing the rumble as the tire gets to that speed and the layers of the tire are under a specific amount of stress. I'd get that pulled and inspected (off the rim) for damage!
Grant
Your personal contact at The Tire Rack
1-877-522-8473 ext# 313
fax# 574-236-7707
email: [email protected]
Old 04-21-2004, 11:54 PM
Dsilver Dsilver is offline
Send a message via AIM to Dsilver Send a message via MSN to Dsilver
Grant is the man!!!
95 Towncar trans problems....help!!!! speeddemon_09 Town Car 4 09-20-2009 10:20 AM
97 ram 1500 sport 4x4 tranny problems HELP ME! tabes Ram Pickup | Ram SRT10 3 03-14-2009 08:56 AM
HElp Help Honda Problem phess Accord/TSX/Accord Hybrid 1 12-28-2005 05:54 PM
HELP HELP Electrical Problems Im 100 percent LOST With my blazer ArcticCat900 S-10 2 12-08-2005 06:43 AM
urget help help help fuel problem john2004 Grand Cherokee | Grand Cherokee SRT8 15 09-15-2004 10:31 PM
