Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-16-2004, 08:35 AM
john2004 john2004 is offline
urget help help help fuel problem
two days ago and when I tried to start my jeep grand cherokee 93 after normal parking it did not start ... the engine was moving but fuel was not coming to the injectors ... I pushed the truck to an electrision ... he checked the cables and then the fuel came and the truck was starting again ...
today when I was truning the truck it went off it self and from early morning till now I couldn't solve the problem ... so please tell me what the reason could be ...
how can I fix the problem
please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please
Old 01-16-2004, 10:20 PM
help help please help my jeep still can't start ....
no fuel is comming ...
no electricity is coming to the fuel pump ...
please help I have alot work to do ... but no jeep ...
Old 01-19-2004, 04:09 AM
a big forum like this ... but no reply ...
anyway ...
you all listen to my story
I used to have my jeep working in a very good condition ...
before 7 days the problems started ...
I parked my vehicle ... near a bank ...
later I started it and everything was fine ...
here the problem started ... the engine stopped running automatically ...
I checked the fuses ... all were fine ..
then I took it to an electrision ... he was just standing when it started runing again and I drove it back to home ...
two days later ... it stopped again when I was driving it and when I was trying to turn ...
First I thought I have ranout fuel ... I found that half of the tank is still there ... I pulled out the fuel pipes ... I noticed that fuel is not comming
I stopped the truck for about 20 hours and then I pulled it to the electrision ... again it started without doing anything ...
I wrote my topic here ...
yesterday it stopped again and till now did not start ...
I checked my vehicle from down side I found that alot of oil leak is under the engine ... so could that affect ...
please help .. somebody told me that the cps is the problem ... others said the fuel pump ... but will the fuel pump run , stop , then run then stop !!!!!!!!!!!!!! ????
Old 01-19-2004, 07:01 AM
michelq michelq is offline
Re: urget help help help fuel problem
sound you have problem with crank angle sensor mounted on bill housing on transmision
Old 01-19-2004, 08:24 AM
but how can I get sure that fuel pump is working fine ?
and if the problem is with the sensor ... where can I find it ...
I searched for the cps in the place you describe but I could not find it ....
I found a clip with 3 wires starting near the coil ends at the staring position on the top of the transmission ... the end is a balck plastic item with only one screw ... it is the sensor ... and I think it is difficult to open ...
Old 01-19-2004, 10:13 AM
mounted on driver side right on top with two bolts 3 wire plug
Old 01-20-2004, 12:19 AM
Gary(cdn) Gary(cdn) is offline
Unhappy Fuel Pump
I just rebuilt my 4.0l and washed it in the shop wash bay, then it wouldn't start.
After three days of various testing and diagnostics (easiest: jump fuse holder with a test light *key on, no light, no pump operation = new pump) We determined that I needed a new $390cdn pump on top of my $2200 rebuild. We extracted the tank which is a long process and the pump tested fine on the bench, until it was emersed in fuel (load) then failed.
SO try jumping power to your pump test light in series it will run no matter what IF the pump is good. if no, sorry
Old 04-08-2004, 03:15 PM
dward357 dward357 is offline
I your jeep is fuel injected their is a test port on your fuel rail. You can hook a pressure gauge to the fuel rail and it will tell you what the pressure is in the fuel rail. That will also tell you if the fuel pump is working.
Old 04-08-2004, 04:26 PM
Dale Aeppli Dale Aeppli is offline
LIKE THE OTHER POSTS SAID CHECK FOR FUEL PRESSURE, THE CRANKSHAFT POSITION SENSOR LIKE THE OTHER POST SAID ITS ON DRIVERS SIDE HELD ON THE BELLHOUSING IT HAS A 3 WIRE CONNECTOR TRY UNPLUGING IT & REPLUGING IT IF IT STARTS THE SENSOR MAY BE GOING BAD. FUEL PRESSURE 35 -48 LBS. DALE
[email protected]
Old 04-09-2004, 03:30 AM
Dsilver Dsilver is offline
Send a message via AIM to Dsilver Send a message via MSN to Dsilver
I think this guy has the right idea on what is wrong with your car.
Old 04-12-2004, 04:28 AM
4X4BOI 4X4BOI is offline
right i need to move my jeep, it is a 4.0 and got sparks, but fuel seems not to want to come, i heard about bridiging the fuel pump wires to get fuel going, but also hear it has something to do with the imoobiliser....so if it is jsut a simple bridging..where would i find te pump and wires to do so?
Old 04-12-2004, 01:00 PM
Re: Re: urget help help help fuel problem
HI YOU DIDN'T SAY WHAT YEAR YOUR JEEP WAS, LOOK UNDER THE HOOD ON PASSENGER SIDE RIGHT BEHIND THE BATTERY THERE SHOULD BE A POWER BOX CONTAINING RELAYS & FUSES. IF SO REMOVE ILD TURN LID OVER IT HAS A DIAGRAM SHOWING & TELLING WHAT EACH RELAY & FUSE IS FOR .FIND THE RELAY FOR FUEL PUMP HAVE SOME TURN KEY ON- OFF. YOU SHOULD HEAR THE RELAY CLICK. IF NO CLICK REMOVE RELAY & REPLACE IT WITH ONE OF THE OTHERS ALL,INTERCHANGEABLE.IF IT CLICKS THEN REPLACE THE RELAY NAPA $ 8.00 DALE [email protected]
Old 04-22-2004, 09:06 PM
Dale how did you get so smart when it comes to Jeeps?
Old 09-15-2004, 10:23 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
what engine do u have, on the 5.2 and 5.9 V8's teh Crank Sensor is on the Passenger side, behind the right exhaust manifold. on 4.0L I6 it's on the Driver side, on the side of the tranny, right above the engine oil pan. on the tranny side.
Old 09-15-2004, 10:30 PM
yes I forgot about the Fuel pPump relay. do what dale tells ya.
