Old 03-23-2004, 09:03 AM
FormulaForce FormulaForce is offline
More bolt-ons?
I own a 1995 Formula Firebird, LT-1 6-speed, with the following upgrades:
4.11 rear gear
Hypertech programming
Hypertech 160 thermostat
Granatelli Mass Air Sensor
Moroso cold air pick-up
Aluminum driveshaft
Flowmaster Cat-back exhaust
March power pulleys
Holley throttle body airfoil
B&M Ripper shifter
Pirelli High-performance tires (stock size)
All-synthetic lubricants
Will soon add:
BBK Headers (wrapped)
Accel U-groove spark plugs/high temp wires
Other than machining the heads and adding a more aggressive cam(which I can't afford), I can't think of anything else to add that doesn't cost a fortune. Anyone know some more cheap power tricks for this car?
Does a high-flow catalytic make that much difference?
Old 03-30-2004, 06:54 PM
Squirrel Nuts Squirrel Nuts is offline
Send a message via AIM to Squirrel Nuts
Re: More bolt-ons?
If you have another 225 you could buy the LT4 intake manifold which will allow for about 20 more hp. I also noticed you said you have a manual which is niiice but are you using anything else to put the power to the ground...like...a sway bar, struts, strut tower brace, any suspension really....i would go for the sway bar first its cheap and really effective, stops the fishtailing which can really cut your times.
98 Chevrolet Camaro
Old 03-30-2004, 08:41 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: More bolt-ons?
OK, do you have the basic's also and just didn't mention them like the TB bypass and IAT relocated and I also have another one but I havn't heard anyone do it yet so I'm trying to keep this one hush hush
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 03-30-2004, 09:52 PM
violator6090 violator6090 is offline
Re: More bolt-ons?
what do power pulleys do?
Old 03-30-2004, 09:56 PM
FormulaLT1's Avatar
Fight the powwa!!!
Re: More bolt-ons?
I think he meant power accessory pulley's
Old 04-01-2004, 08:40 AM
Re: More bolt-ons?
That's true, I should think about some suspension add-ons. Wheel hop during a full-power launch is a real problem, and it does fishtail a lot. I did mean power accessory pulleys. I have the March 2-pc kit with the fast alternator pulley. I put this on with my exhaust at the same time, and it was a major difference in power. Easy too, except for getting the original pulley off the alternator.
Old 04-03-2004, 01:10 PM
cndctrdj cndctrdj is offline
Send a message via AIM to cndctrdj
Re: More bolt-ons?
what about a cutout after the headers
95 TA - fast
92 240 - fun
96 prelude si - lots o fun
94 cr500r - rediculously fast and fun
Old 04-06-2004, 04:43 PM
DarkblueTA's Avatar
DarkblueTA DarkblueTA is offline
Send a message via AIM to DarkblueTA
Re: Re: More bolt-ons?
Agreed. Get Lower Control Arms(Lakewood 85.00 from Summit with poly bushings) first. Then add as you like. Feel free to contact Robert at Extreme Performance in Oklahoma City. They are an LT1 and LS1 shop. They have good prices and do great work. Their number is 405 721 2430. Let them know Matt sent you(Darkblueta).
DarkblueTA
GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit
2007 Nissan Titan Daily Driver. 2* advance
Old 04-06-2004, 07:50 PM
Re: More bolt-ons?
DarkblueTA what kind of times do you run. Your car must be sickly fast with the procharger blower and not to mention the other mods. and also is the procharger all its hyped up to be?
Port/polish or bolt ons? nemesls_2000 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 24 02-03-2004 11:09 PM
Adding HP with bolt ons... ExemptX2000 Engineering/ Technical 28 06-06-2003 11:29 AM
Turbo mag tests V6 w/ bolt-ons VTECseoul Accord/TSX/Accord Hybrid 0 04-24-2002 05:02 AM
98 Accord 2.3L I-4 w/ bolt-ons VTECseoul Accord/TSX/Accord Hybrid 6 03-28-2002 09:16 PM
6th gen Accord w/ bolt-ons VTECseoul Engineering/ Technical 2 03-19-2002 10:06 AM
