Old 01-07-2002, 07:20 PM
ford427fe ford427fe is offline
ignition timing
just what is ignition timing.....what are the degrees and everything else they are talking about...
thanks in advance
Old 01-08-2002, 08:27 AM
enginerd's Avatar
enginerd enginerd is offline
Ignition timing is measured in degrees. If I say 10 degrees before TDC, that means the ignition fires 10 degrees (crankshaft revolutions) before [top dead center (the point in the cylinder where the piston has reached it's peak)]. If your timing is before TDC, it's advanced, if it's after TDC it's retarded and if it is at 0 degrees then its "straight up".
97 Safari turns over but won't start - ignition coil wires? icemuncher99 M Bodies 3 05-31-2010 05:03 PM
Do we have to set ignition timing after timing belt install? MetroManiac Metro 1 07-03-2006 07:47 PM
How to adjust your ignition timing 101. ChuckH Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 17 07-27-2005 03:37 PM
Messed up ignition timing...NEED HELP ASAP!!! VTEC_boi General Discussion 0 01-13-2002 07:13 PM
Advancing ignition timing Primal SMX Engine 6 10-30-2001 09:41 PM
