Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-21-2004, 10:33 PM
bionictony's Avatar
bionictony bionictony is offline
Send a message via AIM to bionictony
what kind of code scanner and connector do i need for my 1994 camry le sedan?
the check engine light comes on periodically on the camry. i wanted to know what kind of scanner and connector does it use to find out whats wrong. where can i find the place to connect it to? i have a 1994 camry le sedan. thanks in advance for your help
Old 03-22-2004, 06:58 PM
Joe W Joe W is offline
Re: what kind of code scanner and connector do i need for my 1994 camry le sedan?
I'm pretty sure the connector is in the engine compartment,but it is the OBD-1 protocol.You could try www.JCWhitney.com or one of those magizines for an inexpensive tester.
Old 03-22-2004, 10:00 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Only connector I know of is under dash by driver.
Haynes manual shows procedure without code scanner in chapter 6.
ignition specs and distributor specs for 1994 camry spookie5996 Camry/Camry Hybrid/Vista 1 09-30-2010 09:04 PM
can anyone help me with what kind of parts I should buy for a 1994 vr4 haroharojoe 3000GT/Stealth 6 08-24-2007 02:39 AM
What type of code scanner do I need for ABS codes brj1 General Discussion 2 04-22-2007 12:02 PM
What kind of clear do i need for taillights(paint) alphalanos Cars in General 0 07-09-2005 02:38 PM
What Kind of Scanner??? 95GrandAmSE Grand AM 2 06-21-2003 06:26 PM
