Old 03-21-2004, 07:33 PM
AaronAlbZ24 AaronAlbZ24 is offline
HELP! My Z24 makes a rattling noise
So if any of you guys can figure this out i'll be happy. My 01 Z24 with 31k on it makes a rattle bearing type noise from the trans(manual) area when its been driven for 30 minutes or so, when it gets hot. You pull into a parking lot and put it in first or even second and hold the rpms out a bit and let of the gas and a noise that rattles, sounds like a dry bearing comes out from it. This only occurrs when its been driven for awhile. After it cools down such in the morning its quite as can be. It takes longer for the noise to occur when the temp colder outside than if it's warmer. Could this be a trans fluid problem or possible presuure release bearing problem, cause the dealer is to lazy to figure it out. If any of you guys have had a smilar noise let me know and what you found out.
Old 03-22-2004, 05:57 PM
Three_Fingers Three_Fingers is offline
Re: HELP! My Z24 makes a rattling noise
There was a TSB on this before...I believe it said to check the motor/tranny mount on the affected side where the noise is coming from-they rattle when they get beat. Usually when load is being applied.
Old 03-22-2004, 10:17 PM
xxchamp34xx xxchamp34xx is offline
Send a message via AIM to xxchamp34xx Send a message via Yahoo to xxchamp34xx
you mean when you rev the engine? I thought there was a safety on it so it wouldnt let you do it, and when i rev mine it makes the same noise with a lot of rattling
Old 04-09-2004, 09:58 AM
canuckgt canuckgt is offline
I am having the same thing with my 2000 gt, it has a 2001 z24 engine in it, with approx. 25000 km. Same thing with the mechanics not being able to figure it out??? it sounds to me like its coming from the from around the timing chain area, sound similiar?
Old 04-12-2004, 01:40 PM
lildog's Avatar
lildog lildog is offline
See this thread under "Cavaliers are garbage" for an insightfull and accurate discription of your problem.
http://www.automotiveforums.com/vbul...aliers+garbage
cutlass ciera making rattling noise assilemassila Cutlass Series 5 11-13-2005 06:12 AM
sunroof makes rattling noises silver98GST Off-Topic 5 01-28-2005 08:38 AM
clutch making rattling noise michaelsd16c '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 03-29-2004 10:12 PM
car makes rattling noise mindajatt 3 Series 1 12-15-2003 09:12 PM
