Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-09-2005, 10:15 PM
assilemassila assilemassila is offline
Send a message via AIM to assilemassila
Question cutlass ciera making rattling noise
I have a 92' cutlass ciera, and it recently started making a rattling noise when i am not pushing on the accelerator, and is loudest when in full stop, brakes pushed or not. the sound is coming from the front passenger's side, and it sounds like there's something that fell off or is lose and is now being rattled around. it started literally out of nowhere...one day it was fine, the next day it was making this noise. does anyone know what it could be? i'd really appreciate any advise!
Old 11-09-2005, 10:28 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: cutlass ciera making rattling noise
A few of the likely culprits are a bad water pump, alternator, or maybe a faulty idler pulley. Pop the hood, start the car, then look at the belt and all pulleys. If any pulleys lean, squeek, or make other odd noises, the accessory it is attatched to is likely bad.
Old 11-10-2005, 08:58 AM
I'll check those, thanks!
Old 11-11-2005, 08:50 PM
Mrbizness1 Mrbizness1 is offline
My Ciera had the same rattling noise you described, turned out to be a aluminum guard by the rack and pinion. I just bent it out of the way
Old 11-12-2005, 01:00 PM
clony clony is offline
i had this isssue before. when u press the accelarator, the noise goes away. Turn out it was the harmonic balancer. Might want to replace that soon if it is cause if falls out, more damage, i think
Old 11-13-2005, 06:12 AM
thanks for the comments
turned out it was the harmonic balancer
