Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 03-21-2004, 03:49 PM
Ron Zambor Ron Zambor is offline
2000 Jetta Radio
Help, the AM reception in my 2000 Jetta has deteriorated yet I still receive FM stations. Anyone have any suggestions as to a remedy for this?
Old 03-21-2004, 11:52 PM
gr8gatzby's Avatar
gr8gatzby gr8gatzby is offline
Re: 2000 Jetta Radio
is it all AM stations...maybe the one station you listen to is having transmission problems...
Old 03-22-2004, 12:22 PM
boschmann boschmann is offline
If all AM reception is failing & FM is worse, then it's most likely the amplified antenna. You have a very complicated powered (not in the up/down sense) antenna, which can go bad in two ways. One is when the ground connection gets some corrosion it will act in this way. Unfortunately getting to things to check it out is a pain. You need to remove the antenna & follow the grounding wire to check it out (not as easy as it sounds). The other is if the amplifier for the antenna has gone bad. Try a search on vwvortex.com "amplified antenna" or "am reception". If you decide to just replace it & go aftermarket be sure you get the proper amplified or powered antenna.
Old 08-05-2004, 12:16 AM
gordonjacobsen gordonjacobsen is offline
I am having the same problem... all of the FM stations are crystal clear, but all AM stations are very scratchy. It seems to be worse when the car is started.... would this still be the amplified antenna or another problem?
Old 08-05-2004, 12:24 AM
gr8gatzby's Avatar
Re: Re: 2000 Jetta Radio
this is a known and well documented issue with VW. the germans apparently don't listen AM, at all, and therefore threw in a half-arse implementation for the countries that do. check out vwvortex.com
Old 10-22-2005, 03:40 PM
bahnfire bahnfire is offline
I had the same problem for about year until I tried a cheap fix that ended up working in my case. I put some dielectric grease on the male threads of the whip antenna and on the female threads of the antenna base. The AM reception is fine now. Worth a try. Dielectric grease can be found at your local auto parts store.
2000 Galant Radio. Looks like it works but no sound GalantDriver89 Galant 0 05-22-2010 07:02 AM
2000 Cabrio Does not initially start, Radio Safe, Clock 1200 ptb123 Cabrio 0 04-11-2009 05:10 PM
2000 Jetta Radio Code H.M. Savoie '97 - '03 1 08-10-2005 12:14 PM
1997 Jetta Radio Troubles justgonnastay '97 - '03 5 09-01-2004 09:29 PM
'02 jetta Radio trouble russ9 '97 - '03 3 10-06-2003 02:19 PM
