Old 03-20-2004, 08:57 PM
kcpapp kcpapp is offline
'89 350 TBI Problems
Just bought an '89 1500 2 wheel drive, The truck is back firing, sputtering and lacks pwr while the truck is moving. It will Idle smooth and rev up fine while in park. Will even rev up while under load on the shop floor but when taken on road test is runs as mentioned. We have replaced the distrubitor, tested all sensors, set timing to 0 deg., replaced the plugs, wires, cap, rotor, coil, even took the cat off to see if that was blocked up but still have the problem. This one has me baffled. Any help would be awsome.
Btw great forum
Old 03-20-2004, 09:53 PM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
Well, since you have changed all the electrical components, then I would try a fuel filter. They are only like $10 at Advanced. If the filter is dirty then it would cause it to lack power and not run great. Could also be maybe a bad Injector. This would definetly account for lack of power and missing, but I'm not sure about the backfiring part. Hope that helps.
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
Old 03-20-2004, 10:30 PM
gen0 gen0 is offline
Re: '89 350 TBI Problems
try running the truck with the breather off and manually inspecting the fuel injectors. I had a similar pronblem with my 4.3l TBI One of the fuel injector connectors was getting worn and would loosen occassionally from normal vibration. In essence, when this happened one of the injectors stopped "firing" and the truck would start starving for fuel. And like you said, it only happened on-the-road.
Also, the same problem can happen with the clogged fuel filter mentioned by CT92
GL!
Old 03-21-2004, 09:27 AM
Thanks guys, I will give it a try today and let you know what I come up with
Old 03-21-2004, 06:42 PM
amac209 amac209 is offline
Send a message via MSN to amac209
try tapping the computer sometimes they get sensitive to vibrations
Old 03-22-2004, 05:25 AM
I got it fixed, Had to rebuild the throttle body and replaced the fuel filter. Thanks to everyone for their help.
'92 K1500 350 TBI stumbles and recovers while braking / slowing down when warm 1993Suburban C/K 2 03-27-2010 06:55 PM
'89 Caprice 305 TBI Problem...... floridagrown Caprice 4 01-28-2009 09:11 AM
1987 chevy 350 tbi problems grey87 Silverado 11 10-18-2007 07:59 AM
MERLIN, Follow up to 350 TBI power problem RS72SS C/K 1 01-01-2004 07:22 AM
95 350 TBI power problems? MERLIN help!!! RS72SS C/K 1 12-29-2003 11:34 AM
