Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 01-07-2002, 01:20 PM
NismoTech NismoTech is offline
Question Cleaning a Intercooler, and Plugs Fowling
Whats up, the last couple weeks I have been fowling spark plugs like a mad man. I replaced them to find a number of them fowled again a week or so after, so I started just cleaning them up and replacing them and when I took out the spark plug and looked on top of the piston head a saw lots of carbine and some oil. My turbine recently started blowing smoke out the exhaust. Now I have heard that if a seal is bad on it, it might be throwing oil into my engine through intake ducts. Today I checked the piping to find oil in there. So I checked my intercooler ducting also and found a layer of oil in the bottom of my intercooler. Does anyone know a good way to flush a intercooler out? Also any ideas on what could be fowling out these plugs so quick? I did do a compression check and they where all about the same so I don't think it the rings and I have a steel head gasket and I made sure it was tight also. Please let me know if you have any ideas. Thanx
- NizmO
Old 01-07-2002, 01:46 PM
swampy swampy is offline
Send a message via ICQ to swampy
Sounds like your turbo might be buggared,as the seals do go in them and blows oil into the motor.This will cause the plugs to foul/oil up.Once the turbo is fixed you can flush out your ic with a engine degreaser to get rid of the oil and in all the intake pipes as well.
cheers swampy.........
cheers,Swampman
after cleaning jets , spark plug are foulled with carpon myslon Engineering/ Technical 6 01-08-2010 03:42 AM
brake light and dashboard cleaning sailor86 Engineering/ Technical 4 12-29-2009 07:40 AM
planning on buying injectors and intercooler and waste gate... fast_driving2007 Performance 1 05-18-2007 11:36 PM
its safe to clean Intercooler using vfaq method ? Killa Engine, Transmission and Drivetrain 5 08-08-2006 08:13 PM
FS - R34 GTR Vspec II stock intercooler and suspension Initial_E Classifieds 0 02-16-2003 08:28 AM
